What would you do with...
  • sailor55330
    • Jan 2010
    • 494
    A 3/4 horse, 1750 rpm electric motor? I have one that is only a few years old on an antique saw that I don't use. Anyone have any suggestions on what it might be good for?
    • 3128
    use it to build one of these ...
    http://www.stockroomsupply.com/V_Drum_Sander.php
      I'd use it to rig a conveyor to bring cold beers to me from the fridge to my TV chair...
      • Chris_B
        • 216
        • Cupertino, CA
        Assuming it can turn counter-clockwise, you could build a *really* powerful version of this 1" belt sander.
        3/4 HP is clearly over the top, but this is - by far - the most frequently used sander in my shop.
        • sparkeyjames
          • 1087
          • Redford MI.
          Save it for when you need it. 3/4 horse motors run close to $200 (for a good brand). Good for drill press, band saw and in a pinch a contractor style table saw just to get you by till you get a new 1.5-2hp motor. Could also be used as a small lathe motor with proper pulley selection. Just too many darn uses to list.
          • Mr__Bill
            • 2096
            • Tacoma, WA
            I just might build one of these if I had that motor.
              If I had that motor I would rebuild my jointer, lol As others have mentioned, save it they are pricey now!
              • L. D. Jeffries
                • 747
                • Russell, NY, USA.
                Which is exactly what I did with my old motor. Had a big piece of melemene (sp) on hand for the top. Total cost from the Canadian company was about $150. Thing work GREAT.
                RuffSawn
                • annunaki
                  • Jan 2008
                  • 610
                  • White Springs, Florida
                  • 21829, BT3100, 2-BT3000(15amp)
                  Many uses
                  While not nearly as powerful, I have used old washing machine motors 1/3 Hp, 1725 RPM for Disk Sanders, 32" Radial Arm Drill Press, & Bench Grinder.
                  They have a thermal overload protection that shuts them down if overheated,
                  so they hardly are ever bad when tossed out with the washer. They have a big capacitor to kick start them under a load (washer full of wet clothes changing cycles) and as such could be used to drive an air compressor.
                  http://en.wikipedia.org/wiki/Fileodecahedron.gif
                    I would say use it to build a wide drum sander. At 3/4 HP it won't hog off a lot of material at once, but it WILL spin a drum pretty well... I am planning on upgrading my band saw to a 1.5HP 220V motor and reusing the HF 1HP motor for a WDS project... But that is down the road a bit...
                    • annunaki
                      • Jan 2008
                      • 610
                      Another consideration
                      You can add a "Step" pulley/ and belt, and have several speeds.
                        How about one of these http://www.bt3central.com/showthread...881#post466881 , sans footpedal.
                          Is 3/4 HP enough to get that thing moving?
                          • Mr__Bill
                            • 2096
                            • Tacoma, WA
                            That is what the hand crank on the side is for. Give it a good spin and then plug the motor in.
                            I still think a big disk sander is a good interim use for the motor. Won's hurt it and is useful. Then when some other need comes up you can discover just how handy the sander was and buy a real one.
                            that's my opinion and I'll stick with it until I change my mind!
