As some of you know, I bought a Grizzly drill press table from Loring a while back. It did NOT like the humidity of being right on the coast, and the fiberboard it was made from, well it just kind of melted. Specifically the section the thread inserts goes into just kind of flaked apart like shale pops off in sheets... I did Gorilla glue it (twice) and epoxy it (once) but the failure this week was the last straw...
So now I am shop building a table. I actually built a prototype already (I am calling it a prototype because I made some bad mistakes on it), and am now gluing up what will be the final table.
The specs are...
3/4" birch ply / 3/16" tempered hardboard lamination table. Replaceable insert cavity routed in place (using the Grizz as a template). Inserts will be 1/2" plywood (I have TONS of that, and can set the depth for my rabbeting bit to achieve this pretty easily...
I will be recycling the Grizzly hardware for the thread inserts.
The T track in the table, and the fence will be Rockler Universal T Track so that I can use regular bolts as well as my many Rockler T bolts...
I am considering edge banding it, but have never done so. Not even sure how to do this other than some sort of slot and tenon arrangement. You guys have any suggestions? The lazy part of me says to heck with it, but another part of me wants to band it to get the practice... And yet another part of me wants to edge it with hardboard for a consistent look...
Well, tomorrow the glue up should be done, and although I will be way too busy for my own good with other issues, I will try to get out to the shop and flush trim the hardboard, and get the edging started... Then I will know...
The specs are...
LCHIEN
