Source for good hardboard?
  • BigguyZ
    • Jul 2006
    • 1818
    • Minneapolis, MN
    I'm looking at building some projects in shopnotes and the like, and every time I look at my local HD, Menards, or Lowes, all of the Hardboard has one smooth side and one furry side. Where do you find the hardboard that has two smooth sides? Is this something I'll have to go to a lumber yard to find?
    Also, where's a good source for adhesive backed sandpaper? (for miter fences and the like?)
    Thanks!
    Last edited by BigguyZ; 05-12-2009, 03:18 PM. Reason: meant sandpaper (in tape form perhaps), not tape...
    • 22106
    Also, where's a good source for adhesive backed tape? (for miter fences and the like?)
    Thanks!
    never seen hardboard (masonite) with two smooth sides. I think that (the fuzzy side) is a feature of the process.
    Adhesive backed tape? What kind of tape? You mentioned miter fences, do you want the wood to slide or not slide against the fence?
    like UHMW or teflon tape (slick)? Scotch tape? Masking (painter's) tape? Duct, electrical, etc. Sandpaper with PSA backing?
      Tempered hardboard is smooth both sides (or at least all that I have seen has been). It is difficult to impossible to find at the big box stores; a good lumber yard or a friendly cabinet shop would be better bets.
      Depending on the application, 1/4" MDF, if you can get that, can often be substituted for hardboard. The Home Depot here carries 1/4" MDF, in addition to 1/2" and 3/4", but Lowe's has only the latter two.
      If you mean double-stick tape, I usually get mine from Highland Hardware in Atlanta.
      • BigguyZ
        • Jul 2006
        • 1818
        • Minneapolis, MN
        I meant adhesive-backed sandpaper. Sorry. But is that something a B&M store (big box) will have? I've looked...
        All of the designs using hardboard show tempered hardboard, not the std fuzzy stuff. Do you think there'd be much of a difference? I want to make the shopnotes Dovetail Jig Station... and that calls for tempered hardboard for the stops... I guess 1/4" MDF would work, but I like of the the contrast of the dark hardboard versus the plywood...
        Thanks again!
        • Tom Miller
          • 2507
          • Twin Cities, MN
          It comes and goes at the HD & Menards that I go to, but I recently purchased hardboard at HD (in Woodbury) that is smooth both sides. It's 3/16", and not 1/4" if that matters.
          Otherwise, I've been substituting 1/4" and 1/8" MDF, due to its availability, and also wanting smooth both sides.
          Regards,
            The big box stores will probably have 5" and/or 6" PSA (pressure sensitive adhesive) discs, for random-orbit sanders. I don't know if they'd have anything else ... you might have to go to an online vendor like supergrit.com or Klingspor's.
            You mentioned "stops" ... I think I may know the dovetail station you mean. If I'm remembering it correctly and you only need small pieces, old-timey clipboards are made out of tempered hardboard and only cost a couple bucks each. That might be one dodge that'll get you the materials you need. They won't be 1/4" thick, though; more like 1/8".
              You can get adhesive backed sandpaper in a roll, LIKE THIS. Most of the sheet goods suppliers I use carry tempered masonite in 1/8", 3/16", and 1/4", that's smooth on both sides. The same suppliers carry hardwood plywood, melamine, and some carry hardwoods. They sell primarily to the trade, but some have "counter sales" to sell to the general public. You might find them in your area. They are usually listed under "plywood" in the yellow pages. Or, call some local cabinet shops. They may have it or direct you where you can get it.
              • Tamarack
                • Oct 2003
                • 199
                • Speedwell, TN USA
                I suggest you talk to one or two of the cabinet shops in your area, many will add your needs to their order and you go to his shop to pick it up after the supply truck makes his delivery. I was having a hard time finding a source for Baltic Birch plywood within reasonable driving range and took this option, got exactly what I wanted and very little of MY gas was used. The price was fairly reasonable as I paid half in advance and the rest C.O.D. so the cabinet shop did not have any of their money tied up in it. S2S tempered hardboard in full 1/4" is also readily available this way.
                Paul
                  What Larry said, try a lumberyard. In fact, if you call them and tell them you need tempered smooth two sides they'll know exactly what you're talking about, and probably have a lift of the stuff.
                    On the self adhering sandpaper for the fence I use some intended for my Scary Sharp I get from Klingspors site but it does come in rolls and probably more than you need. I have seen the self-adhesive sandpaper at the Box stores used for safety grip on steps.. floors.. etc. in shorter strips there. I have never bought any as my BIL is a shop foreman at Delta Air Lines and brings a roll occasionally. They use it on ramps.. step-ups on ground support vehicles.. etc.
                    3M spray adhesive will work on regular sandpaper also.
                    Good luck..
                    • gsmittle
                      • 2793
                      • St. Louis, MO, USA.
                      Over the weekend I found 3/16 tempered hardboard smooth on both sides in my local Lowes. It was in the flooring section, not lumber.
                      g.
                      Smit
                      "Be excellent to each other."
                      Bill & Ted
                      • BigguyZ
                        • Jul 2006
                        • 1818
                        • Minneapolis, MN
                        Regards,
                        Hmmm.... I may have to drive out there next time I get bored and check it out. Full sheets, or handipanels (either 2x4 or 4x4)? I have a sedan, so I'm not fitting a full sheet in there (unless I cut it down first).
                        Thanks!
                        • BobSch
                          • 4385
                          Try Youngblood lumber for the hardboard and Acme Tool in Plymouth (next to Hom Furniture on 494) for the adhesive backed SP.
                          WARNING: Acme is an adult candy store. Leave your plastic at home. DAHIKT
                          Bob
                          • BigguyZ
                            • Jul 2006
                            • 1818
                            • Minneapolis, MN
                            The problem I have with Youngblood is that they are almost impossible to go to because of hours... Maybe I can drop by Friday during the day (I work from home that day).
                            Is ACME cheaper than Woodcraft? a 4.5" by 30' roll's $22 there.
                            Thanks!
                              I thought of this sometime last night, after I went home. Every shop needs a can of 3M #77 spray adhesive.
                              Alternatively, you can make your own "adhesive backed sandpaper" using double-stick tape (what I usually do, for jigs and fixtures). Every shop needs a couple rolls of that, too.
