I built a shed after Wilma, it's 10' wide, 12' long. I stick built it with 2x4's, 16" O/C. I used ⅝" T-1-11, grooved 4" O/C, stapled in place with 1½" narrow crown staples.
So, in 7 years the bottoms of the siding have rotted. My first thought was to run a skil saw horizontally and fit in new siding with a "Z" type flashing. But, after thinking about it, I decided that it would not be the best fix. My thoughts are to use 5/16" Hardiboard (cement board) instead. I would remove all the siding to do the refurbishing. From the specs it's supposed to be fairly impervious to exterior conditions.
Here are my questions:
1. I haven't used Hardiboard. Is Hardiboard the best material to use?
2. What is the best way to cut it?
3. Can it be stapled in place, or does it HAVE to be screwed on?
4. What's the best way to cap the vertical corners (where one side meets the other).
5. Are the long edges square to the sheet, or are they stepped to fit, like the T-1-11 is?
6. If the long edges are square, is using an exterior caulk to the mating edges recommended, or is there a "T" moulding that is used.
7. I plan to do one side at a time, and I'll likely need 11-12 sheets. What's the best way to store the sheets until they get used...(on edge or flat).
Thanks for any help. Below are pictures of what I'm starting with:
