Need Advice For Shed Repair
It seems like you need something over the studs regardless of what siding you use unless you go back to painted siding. I wouldn't want OSB near the ground either. I once used tile backer board, concrete board, as a siding material on a shed. It was unusual but worked fine. You could run it around the bottom of the shed and move to OSB above it. Or you could use plywood to better match the thickness.
JimComment
I feel that hardiplank is the best siding you can use for any structure. I have applied it to several houses and garages. I use the spiral hardboard nails. Yes they are hand nailed. I doubt you will get a staple thru it. And yes, you will need a backer board. Why not just nail over the siding you presently have? Cut the bottom board a little shorter so water can't get to it. And let the starter row go below the cut you just made.
Most decent lumber yards have the PVC (Azak) material for the corners. Not the big box stores. I am with you as I use polyseamseal for most joints. Another good alternative is "White Lightning". It is an adhesive caulk just like polyseamseal and is acrylic latex. Works as good at half the price. Lowes sells it for about $1.80 per tube. I use so much of it I usually buy it by the case and save even more.
Hope this helps,
ConwaygolferComment
At first I was thinking to take off the existing siding. I didn't want to do a repair where it required cutting off the rotten parts and fitting on new siding. Instead, I can just rough cut off the rotten stuff. Then fasten PT 1x6 or whatever as a ⅝" filler singfor thickness, right at the bottom edge. Then apply the cement board using the T-111, as a backer.I feel that hardiplank is the best siding you can use for any structure. I have applied it to several houses and garages. I use the spiral hardboard nails. Yes they are hand nailed. I doubt you will get a staple thru it. And yes, you will need a backer board. Why not just nail over the siding you presently have? Cut the bottom board a little shorter so water can't get to it. And let the starter row go below the cut you just made.
Hope this helps,
Conwaygolfer
.Comment
Leaving the existing siding would be a good idea. It'll save some time and effort too.At first I was thinking to take off the existing siding. I didn't want to do a repair where it required cutting off the rotten parts and fitting on new siding. Instead, I can just rough cut off the rotten stuff. Then fasten PT 1x6 or whatever as a ⅝" filler singfor thickness, right at the bottom edge. Then apply the cement board using the T-111, as a backer.
Instead of PT wood as the backer/repair you might see if a supplier has hardieplank or some synthetic trim. That could be used on the corners too. The non-wood should help on the bottom near grade where water will splash back up off the ground. That's probably the cause of your current rotting.
I cut off the bottom 15" of the T1-11 down one side on my shed a few years ago. I used a PVC Z flashing at the joint and caulked both sides of the flashing. I put a couple coats of some elastomeric paint on the bottom edge of the T1-11 that is exposed and it has held up great. A lot better than a small section on the front that I replaced a few years earlier, but didn't protect. It needs replacing again.ErikComment
I would prefer to use something other than wood for the filler at the bottom. I did check the local box stores for PVC boards that could be used. I would need ⅝" thickness to level out to the T-111. I would want something that is also impervious to rodent activity. Maybe I could just double up the Hardiboard.
I was also thinking that the full sheets are about 80 LBS. Since I'd be working alone, I would have to cut it to the correct height, and install it so it is properly positioned. I am disappointed that a staple might not work. If it did, it could be used as a position holder, to further proceed with nails. I couldn't hold a sheet up with one hand and nail with the other. I'm pretty strong, but that would take three hands.
So, I'll configure a ledger of sorts that sits on the ground that I can just set the bottom of the sheet on. That would align the bottom where it has to be. I'm going to experiment with staples on a sample and see what happens.
.Comment
If you can find either Hardiboard trim or PVC trim, you could install a piece at the bottom. It would trim the bottom plus provide you a ledger to install the new siding.
Does the foundation slab run out past the shed perimeter? How far above exterior grade does the siding start?Comment
I would still have to add the filler where I cut out the rotted sections. That total thickness would be 15/16". If I add a trim base (¾"), only ⅛" of the Hardiboard would be riding on it. Maybe not that big of a deal...worth considering.
The foundation is a 2x6 on edge, on grade. It's topped with ¾" CDX. So, the bottom edge of the siding is above grade by about 5¼".
.Comment
Check to see of they have hardieplank. It's a 5/16" thick board in 12' lengths and varying widths. http://www.jameshardie.com/homeowner...nkLapSiding.pyI would prefer to use something other than wood for the filler at the bottom. I did check the local box stores for PVC boards that could be used. I would need ⅝" thickness to level out to the T-111. I would want something that is also impervious to rodent activity. Maybe I could just double up the Hardiboard.
You'll have to deal with the lap joint parts, but it should work for the material you have to replace. I just screwed my ling sawboard to the shed and used it as the guide when cutting off the old siding with my circular saw.ErikComment
