This is one of our first floor windows which needs exterior trim replacement.
The wood is the pre-primed fingerjointed stock you can find at HD. It's
gotten wet and is rotting out. You can see the chunk I removed with just
my fingers. The siding is Hardiboard so I don't worry about those boards. I
noticed there was no rubber flashing behind these trim boards, though.
I was going to use PVC but that's about 3x more than wood. This trim is
original to the house and made it at least 12 years. It's been on the decline
since we bought the house. Hard to say if we'll be here another 10 years.
The install of new boards seems pretty straightforward except for the metal
drip edge flashing at the top. It should be Z-shaped and slip underneath the
siding above, right? Is that supposed to be replaced along with the trim?
Wasn't that installed before the siding, though?
Thanks,
Paul
Thanks,
Paul
twistsol
