Proper wiring of middle run duplex recpt with 3rd cable
  • ivwshane
    • 446
    • Sacramento CA
    What's the best way to wire this (either required for code or most efficient but still meets code)?
    I have three cables (2 wire nm) going into a box, one "in" and two "outs" (nothing is on a switch).
    Can I pig tail everything and just have one wire (1 black, 1 white, 1 ground) go to the receptacle or should I have the "in" wired to the receptacle and have the two "outs" pigtailed and then connected to the receptacle?
    • 22030
    too many wires in that box. The proper way to run that is to run one in and only one out wire to each box and daisy chain them.
    • Tom Slick
      • 2913
      • Paso Robles, Calif, USA.
      • sears BT3 clone
      Is it an existing box or something you are installing?
      • ivwshane
        • 446
        • Sacramento CA
        It's a combination of both. The box was existing but I needed another box above it (there was already one to the right of it).
        Really? I've seen a lot of examples of three cables in a single box (the box I'm using is 20.25cu in).
          • 22030
          maybe not a code thing, but its a lot easier to find two spots on the outlet to wire to than three, and the wired outlet will be a lot easier to stuff back into the box with two wires attached instead of three, esp. if you are using 12/3 ga solid.
          • BigguyZ
            • Jul 2006
            • 1818
            • Minneapolis, MN
            I'd personally say that 3 lines is fine in the box. As long as you have a bod that can accomodate them (some are deeper than others).
            I'd pigtail them all and have a wire going out to your outlet.
            I'm not an electrician, but I've played one at home and that's how I'd do it.
