Bye Bye Stump
    Originally posted by dbhost
    Now I need to pray for no rain this weekend... My idea is to pick up about 2 or 3 large bags of Walmart's large briquettes. They burn slow and hot. But not too hot.
    I've been real lucky with dry weather. As for briquettes, I used up the last of our Kingsford twin bag specials from HD. I happened to pick up a couple of the cheap Winn-Dixie brand bags on my last visit there. I found no difference.
    I had a brainstorm looking at the last of the charred wood. There's only a little of the charred wood close to the grade. When the heat dies down, I'm going to try my air hammer, with the chisel attachment. When I've used a shovel it seems to break off straight down. The air chisel might be less work and work better.
    I'll keep ya posted.
      Yeah, curious to know... I had a neighbor that burned a pine stump out. Boy did that one really go! I guess it was all the pitch... But this stupid beech, boy I tell ya, it's like trying to burn green oak. And this dumb thing has been dead since September 2008!
      Like I mentioned before I will be happy with dead, and turned to chars below grade. Obviously I would prefer totally gone and out, but I will take what I can get at this point, as long as it doesn't try growing back...
      I was going with the Wally world briquettes because they are CHEAP, and the large size of the briquettes makes them a little easier to arrange to keep the heat where you want it... And I am not wasting my Kingsford Mesquite stuff on this job...
      • annunaki
        • Jan 2008
        • 610
        • White Springs, Florida
        • 21829, BT3100, 2-BT3000(15amp)
        Old Vacuum Cleaner Method
        I needed to remove a stump that was too close to a cement stoop to permit a lot of digging.
        I started a fire on top using self starter charcoal.
        Once started, I took an old Electrolux Vacuum and reversed the hose so that it blew air. The charcoal quickly got grey. Next I added real coal on top of the charcoal. Once the charcoal had been consumed and the coal was well fired, I was getting blue flames as I watched the stump disappear using my homemade "Forced Draft Blower", which like a bellows on a forge created a blue heat far in excess of any ordinary yellow/orange regular fire. In an hour, the 24" diameter stump was history.
        http://en.wikipedia.org/wiki/Fileodecahedron.gif
          That is more tempting than you can imagine... I can swap my shop vac hose around to blower configuration (Thank you Ridgid!)... I might just have to do that.... Probably drive my neighbor nuts... Only question though. Where do you get regular coal?
            That vacum cleaner method is similar to how I get the charcoal ready in a built in grill that was made into the backside of our fireplace. I have a 120v 4" fan from radioshack that is fastened to a rectangular piece of plywood, part of a metal thru wall fitting for a dryer duct is fastened to the other side. The thing puts a steady, slow movement of air onto the coals. That piece of dryer duct is about 14" long. The fan is really quiet too.
            • Mr__Bill
              • 2096
              • Tacoma, WA
              Pennsylvania.
              • gjat
                • 686
                • Valrico (Tampa), Florida.
                Why don't you hire a stump grinder? I had a huge stump and the stump grinder turned it to sawdust in 10 minutes. It took longer to load and unload it. No fire, no complaints. Easy-Peasy!
                  Average price here is $125-$150.
                    36" clearance required. My gate opening is 32"... And the stump grinder guys don't want to sidehill 4 wheel their trucks down the bayou while yanking a stump grinder for some reason...
                    • gjat
                      • 686
                      I've been told for years that 4" isn't even worth mentioning.
                      • Woodshark
                        • May 2006
                        • 158
                        • Atlanta
                        #26
                        I have burned out five or six good sized stumps using plain old bag charcoal. When we had the house built, the HVAC guys left a small roll of 12" sheet metal behind. I cut off about 4ft of it and, using a couple of drywall screws, made a circle to go around a stump. Pour in the charcoal, douse with charcoal starter and let-r-rip. For my stumps it took about 24 hours each to smoulder and burn them below grade.
                        I have a few more to go but just waiting for charcoal to go on sale again.
                        sigpic
                        • Mr__Bill
                          • 2096
                          • Tacoma, WA
                          That's a clever idea, putting a chimney on it. However nothing beats the spectacular sight of a gallon of gasoline igniting like a rocket to the center of the earth, although you way I expect is a mite bit safer.
                          it's only dangerous if someone you like gets hurt.....
                          • os1kne
                            • 901
                            • Atlanta, GA
                            Very good idea! It would seem that you could do the same thing with the metal exhaust vent material (like for a dryer, etc.). Thanks.
                              Memorial day weekend... Charcoal is presently on sale at HEB, Krogers, and I think Walmart...
                              I am going to run out and grab a few bags, and I think I have some sheet metal torn out from an old AC somewhere... This might just do the trick... I am so close to grade, but I bet that metal ring would help me keep the charcoal where I want it...
                                Roof flashing is pretty cheap.
