Replacing a wired doorbell key
  • SHADOWFOX
    • 1232
    • IL, USA.
    • DELTA 36-675
    Folks,
    This might sound like a stupid question but our doorbell key (transparent plastic part that is pressed) by the front door broke and I went to Home Depot to get a cheapo replacement ($3.00) and my question is do I have to turn off the power before replacing this or can I just replace it without turning the power. Have not replaced one of these before and did not want to have to switch to a wireless unit.
    Thanks!
    Chris
    I replaced one years ago, and I didn't shut off the power. I just transfered one line at a time and didn't let them touch. I don't remember the voltage, but I know it has a stepdown transformer (my belief is 12v).
      I've changed those and mine were low voltage (transformer), and didn't shut off the power. I'm not saying don't shut off the power. I've always done crazy things.
      • BobSch
        • 4385
        Doorbells run on 12v or less. No need to turn off the power. Just don't cross the wires too often while changing the button. It'll drive the dog nuts!
        Bob
        • SHADOWFOX
          • 1232
          • IL, USA.
          • DELTA 36-675
          Thanks guys!
          I'll get on it when I get home from work tonight. Wife has been getting on me for over a week now. She has some people coming over this weekend so she won't let up on it.
          Kind regards!
          Chris
          • phi1l
            • Oct 2009
            • 681
            • Madison, WI
            everyone is right, you don't have to turn off the electricity, .. but I wouldn't touch both wires with my tongue either
            Mine checks out to 18V though..
              • 22052
              looking at the web on doorbell voltages is very confusing. I recall 24 volts.
              Web references mentioned voltages from 6 to 24. One reference said 10 for buzzers and bells and 16 for chimes.
              ANyway, its AC, not DC.
              You can safely handle all the voltages i mentioned w/o danger.
              Just don't short them out or you could damage the transformer.
              • eezlock
                • 997
                • Charlotte,N.C.
                replacing a wired doorbell key?
                I never heard it called a "key" before...but I'm assuming you are talking about
                the pushbutton...correct? No problem, they are are wired on 12/24 volt transformers. Don't let the wires touch each other, if you do, the indoor chime will sound off same as if the button has been pushed.
                • phi1l
                  • Oct 2009
                  • 681
                  • Madison, WI
                  Here the door bell uses the same transformer as the furnace controls, soI think the over riding consideration is what the relays require to operate.
                  • billwmeyer
                    • 1868
                    • Weir, Ks, USA.
                    Originally posted by SHADOWFOX
                    Thanks guys!
                    Kind regards!
                    In that case change the button when she is home and cross the wires alot!
                    • eccentrictinkerer
                      • Aug 2007
                      • 669
                      • Minneapolis, MN
                      • BT-3000, 21829
                      I've received a 'tickle' from a 24 VAC circuit, but I was sweating on a 90 degree day.
                      I've also felt a tingle from a 12 volt battery!
                      I was wearing shorts, the temp was in the high 80's and I was working on my '64 Corvair convertible. As I leaned against the chrome bumper and started wrenching the the bolt on the positive terminal I definitely felt a slight shock.
                      I've been in the electronics biz my whole life and never thought this could happen.
                      Maybe I should gone into railroading. I'd have made a great 'conductor'!
