Another fixing flourescent fixture
    I have a couple 4' lights in my shop. They have plugs on them - I replaced the fixture in the ceiling box with an outlet. 1 light is not working. It is the fixture and not the bulbs or outlet. I am assuming ballast but have not opened it yet to see. Is it worth fixing or just buy a new one?
  • jziegler
    • 1149
    • Salem, NJ, USA.
    Most likely just buy a new one, unless you want a better ballast. Most of the ballasts that I have seen to buy seperately are higher end ballasts than a shop light will come with. I think that many shop lights are still using the older magnetic ballasts (think the ones with more flicker, possibly hum) rather than the electronic ones. Electronics ones cost a good bit more. Unless you get a headache from lighting with the magnetic ones (I can at times), I'd say just stick with them for the shop.
    Also, there are many types of ballasts and finding the right one may be a challenge.
    • WayneJ
      • 785
      I replaced the 4ft lights in my shop, to many problems. Mainly because they don't work when cold. I got 2 8ft VHO fixtures with cold weather ballasts There in about 3 yrs and I have yet to change a bulb. Now I have light in the winter.(summer to) A little more $$$ but worth it.
      Wayne
      Wayne J
      • 91FE
        • 303
        • Philadelphia (actually Souderton), PA.
        from the other thread...
        Originally posted by 91FE
        Originally posted by JSUPreston
        Another cheap but slightly more expensive option: new lights. I know the local BORG has Lithonia Lighting units that are about $8 each.
        Yup. I went to the BORG a few weeks ago for a replacement ballast... came home with a whole new fixture for a third of the price.
        I like Wagoneers too. Hey...they've got wood
          • 22098
          If you're like me you buy the cheapest shop lights.
          If you have cheap lights then they use primarily electronic ballasts these days. Replacement magnetic ballasts foran older fixture will cost more than a new light fixture. If you have a newer fixture it pobably can't be repaired.
            I was told by a shop electrician that magnetic ballasts outlast the newer electronic ones. At least, that was his experience. Anyone confirm this?
            • WayneJ
              • 785
              I have two of the older fixtures in my basement. they were here when I bought my house , and thats 28 years ago.One of them uses starters and they both work fine.
              Wayne
              Wayne J
                For the two light shoplights, it doesn't pay to replace the ballasts. Lowes has a two light 4' shoplight with plug and pull chain for around $8.00. Haven't used a flourescent with starters till we set up some aquariums. Noticed that the starter sparks. Might not be a good idea in a shop environment.
