dead dryer......
First off, get a multi meter at Radio shack or Borg or Lowes about $10.00
will work just fine. Then, take off the dryer receptacle cover, usually one screw in the middle of the cover, and then proceed to test the terminals.
The ones at a 45 deg. angle are the hot (power) terminals. The one at the
middle( straight up and down is the ground terminal. Between the two
hot terminals the voltage sholud be 220-240 volts, between either hot terminal and ground should be 110-120volts. If these check out normally,
your problem is in the dryer itself. Hope this helps....eezlock
Welcome to the school of life
LCHIEN
