We're remodelling our powder room, and LOML decided on some bamboo plank t&g flooring that we'll be installing over the existing pine planks. The new flooring will be at 90 degrees to the existing planks, which I've nailed down solid & flat. Normally I'd just pull up the old flooring, but the previous homeowner had partition walls built on top of it, so it would be more of a hassle than I'm up for.
I've read up on all the basics, and we're planning to rent a flooring nailer. I'm not planning to put anything between the layers unless I hear otherwise from you guys.
I've never done t&G before, so I'm looking for any brilliant tips that will save me headaches during the install.
Thanks!
Thanks!
