Newbie Question re nailers
    quote:Originally posted by WoodRook
    Thanks for the reply Loring.
    One other question for anyone's consideration. This gun weighs in at 4.25 pounds which seems hefty to me. I picked up a Tradesman brand 2" brad nailer at Lowes & it felt much lighter (but I don't know what it weighed). Is the 4+ pounds considered a light, typical or heavy weight for a 2" gun?
    I ask because of rhuematoid arthritis in my wrists/hands (not because I'm a [Arnold] girlie-man [/Arnold].....)!
    How do you know its 4+ lbs? did you weigh one at HF, or did you read it on HF's site? Sometimes weight is shipping weight and not tool weight. Sometimes (and I know this is true) there's lots of typos in the HF descriptions and stuff, so don't rely on it 100%. I'd be real surprised if their cheapo gun weighted a lot more (2X) than other cheapo guns.
    • BobSch
      • 4385
      That 4 pounds has to be shipping weight. No way is the gun itself that heavy.
      Bob
      • golfmore
        • 227
        • Centennial, CO, USA.
        Just bought one at HF. It came up $49, and with add was adjusted to $19.99.
        • WoodRook
          • 101
          • Endicott, NY, USA.
          Loring, Bob - I took the weight from the website so I have no idea if it's right or wrong. From the HF link above : "Weighs only 4.25 pounds"
          Any owner's care to comment (or better yet weigh their gun for me)? Thanks.
          WoodRook
          • Brian G
            • Jun 2003
            • 993
            • Bloomington, Minnesota.
            • G0899
            I just now used a hanging scale to weigh my 46309 nailer. The scale indicated it weighs 2.9 lbs.
            I weighed the nailer in the case, and it weighed 4 lbs.
            Brian
            • WoodRook
              • 101
              Thanks Knuckles!
              WoodRook
              • gbutler
                • Mar 2005
                • 21
                • Roland, OK, USA.
                Thanks for the info on the nailer. What about compressor? What's the minimum size I will need for nailing and maybe some light painting?
                Gary Butler
                • WoodRook
                  • 101
                  #23
                  I'm far from an expert but nailing & spraying have vastly different requirements. Most any compressor will shoot brads or finish nails but you need lots of air to paint which requires a much larger compressor.
                  WoodRook
                  • gbutler
                    • Mar 2005
                    • 21
                    • Roland, OK, USA.
                    #24
                    Thanks for all the input on nailers. Although I don't have a compressor yet, I picked up the HF 3/8" to 2" brad nailer for $19.99 at my local HF store.
                    I couldn't wait to try it out so I stopped at my brother in law's house to hook it up to his compressor. I nailed a few pieces of wood together just to try the thing out. Works great!
                    A quick question though. The documentation that came with it is the usual HF type instructions. Where do I put the air tool oil?????? I didn't see any holes for the oil....
                    Gary Butler
                      #25
                      Put about three or four drops (no kidding: that's PLENTY) in the air inlet on the nailer before you connect the air hose.
                      Do this each time you use the gun unless you're only shooting a handful of nails, in which case you might skip it if you've oiled the gun recently (last day or two). You don't want to go too heavy on the oil because it'll blow out onto your project and stain the wood and/or screw up your finishing.
                      Use air tool oil, which is sold in small bottles in the same area you'll find nails/brads/staples. Couple-three bucks for a small bottle, will last you forever.
                        perfect advice.
