Info needed...
  • Wizard
    • Jun 2009
    • 7
    • Alachua, Fl
    Info needed...
    Good morning, all.....I am building a table for my drill press. I've never installed T-Track before, and am curious about the sizes. Should I uses the 3/8", 1/4", or mini T-Track? The closest thing we have to a woodworking store around here is Lowes and Home Depot....can't remember seeing any in either, so I will have to order, without any hands on first....
    I really like this site.....lots of good info here....thanks.....
    WELCOME TO THE FORUM
    I would use this "T" track.
      Cabinetman is on the right track (pun intended...)
      I have the entire kit not just the track. You are going to want the T bolts and star knobs as wel..
      Rockler puts these sets on sale pretty often for about $20.00. I stocked up, or more correctly, my lovely wife stocked me up for my B-day this year. I REALLY need to use more of it than I have...
      • Wizard
        • Jun 2009
        • 7
        • Alachua, Fl
        Thanks for your responses....will look it over and get it on order.....thanks, again.....
        • steve-norrell
          • 1001
          • The Great Land - Alaska
          You should be alert to the fact that not all T-bolts fit into all T-track slots, especially when buying from different sources. I have had to do a little filing from time to time to make T-bolts fit -- a minor annoyance rather than a serious problem.
          Regards, Steve
            • 22109
            i find it most convenient if the t-track takes 1/4-20 hex head bolts. The new t-track from rockler (that cab man linked to) does. Most do but a few don't.
              If you're ordering from Rockler online, try using promo code V9770 for a 20% discount on one regular-priced item (some other restrictions apply, but it should work for the miter track).
              • Wizard
                • Jun 2009
                • 7
                • Alachua, Fl
                Thank you all, so very much for the info.....
                  Woodpeckers has some neat tracks and fixtures. http://www.woodpeck.com/dptrackkit.html
                  I picked up a couple lengths of some Incra track from Woodcraft for my intended drill press table. I liked the T-Trak plus with the integral rule. http://www.woodcraft.com/family.aspx?familyid=3911
                  • tommyt654
                    • Nov 2008
                    • 2334
                    Try Harbor Freights Drill Press Extension Table $30
                      • 22109
                      Looks like the same table sold by griz and MLCS for a similar low price.
                      http://www.harborfreight.com/cpi/cta...emnumber=96395
                      I think I sold mine to DBHOST. OK, not great.
                        Consider also the t-slot router bit. I've never used a single piece of aluminum t-track, I just route my slots right into my tables. Works great, fast, inexpensive. And it is stronger than you'd think, maybe even stronger than the aluminum t-track because you aren't relying on the small wood screws that hold the aluminum track in place.
                        http://www.rockler.com/product.cfm?p...t%2Dslot%20bit
