Router Speed Control on Drill Press?
  • dkerfoot
    • 1094
    • Holland, Michigan
    Just curious if anyone knows if it is OK to use one of the external router speed control boxes to adjust the speed on a DP. I am guessing that they are intended only for universal motors and wouldn't play nice with the induction motor on the DP. Correct?
    I've got a 5 speed DP that goes down to 500 RPM and I was just curious if I could safely lower the speed using the router speed control box.
    Thanks!
    Doug Kerfoot
    KeyLlama.com
  • Tom Slick
    • 2913
    • Paso Robles, Calif, USA.
    • sears BT3 clone
    you are correct, they only work on universal motors. you need a variable frequency drive to control the speed on an induction motor.
    • phrog
      • Jul 2005
      • 1796
      • Chattanooga, TN, USA.
      Variable frequency drive? What's that?
      Richard
      Richard
        Richard
        The speed of a induction motor is more or less tied to the AC line frequency.
        So you need basically what amounts to an inverter with a variable freequncy output. Run it at 30 Hz and the motor runs at half speed.
        you also need a AC to DC unit. Put it all together and you have a 60 Hz AC in to variable speed AC out or what they call a variable speed drive.
        Everything has to be properly sized for the loads.
        • dkerfoot
          • 1094
          • Holland, Michigan
          Reaching way back to my Navy days - it is called a Variac, right?
          Doug Kerfoot
          KeyLlama.com
          • phrog
            • Jul 2005
            • 1796
            Thanks, Loring. That's what I love about this site - I get an education every time I log in. Again, thanks.
            Richard
            Richard
            • jziegler
              • 1149
              • Salem, NJ, USA.
              No, a variac is a variable transformer. It varies the output voltage. An induction motor speed doesn't vary based on voltage (much), but frequency. Now, a variac is fine to control the brightness of a lightbulb, might work on a universal motor, but would not work on an induction motor.
