Cutting 1/4" templates
  • THyman
    • 315
    • Atlanta, Georgia, USA
    I would like to get your advise on what and how to cut templates. I know that you use hardboard but what do you use to cut straight lines and rounded corners for router table and drill press inserts. Do you first drill holes in the corners and then use a jigsaw to connect the corners?
    Thanks for all of your help.
    War Eagle!
  • Thom2
    • 1786
    • Stevens, PA, USA.
    • Craftsman 22124
    If you already have an insert to use as a pattern, you can easily use it and guide bushings to make a perfect fit.
    Check this thread
      Check this thread
      I'd cut a slightly oversize template, double-stick tape it to the
      original insert and use a router in a table with a top bearing Flush trim bit.
      Then make all the rest from the template the same way.
      • Thom2
        • 1786
        • Stevens, PA, USA.
        • Craftsman 22124
        I was forced to do it that way with my Jessem lift, and would probably do it that way in most cases, but I would be tempted to skip this step depending on the application/insert.
          I've done a little template work over the last year or so. The main thing I learned is that you should take your time making the template because you want it to be "just right". Once you do that, the things you make using the template can be readily dashed out, without much stress or strain.
          No matter what you have available to cut with (jig saw, band saw, scroll saw, etc.) , plan to cut outside the intended size, then shape the template. Hardboard and MDF are very easy to shape using Sureform, files, and sandpaper. With a little care you can get the templates perfectly sized.
          Now you can just carpet-tape the template to your stock, cut to size, then clean up with a bearing-guided bit on your router. Very easy and repeatable.
          HTH,
          • THyman
            • 315
            Check this thread
            So for an insert in a drill press table if I don't already have the insert made, I should make the insert first then use it as a template to cut the table?
            War Eagle!
            • Thom2
              • 1786
              • Stevens, PA, USA.
              • Craftsman 22124
              yes, you will need to make the insert first (or at least a pattern of the insert), but you will use the insert to MAKE THE TEMPLATE to route the opening ... NOT AS THE TEMPLATE to route the opening (just so we're clear on that)
              Practice with some scrap to get a feel for the process and make sure it'll work for you. Don't use cheap masking tape, it will throw you a fit. Also, it may take more/less wraps on the 1/2" guide bushing. It all depends on how well your bit is centered, and the condition/wear of your bit.
              This is the ONLY way that I will do inserts from now on tho'. The fit is PERFECT and the process is FAST once you catch on to it's nuances.
                I do quite a lot of template work. I typically use MDF, but have in a pinch used 1/4 ply. I will usually use templates intended for flush trimming, and often use a spiral cutter when doing that trimming. Sharp inside corners are a failing of templates, you cannot make them. So you are still stuck with sharp chisels to clean up that last bit of material.
