Ruler on edge? Do you have a means of ensuring that ruler is completely square to the fence? Does it have a 'flat' that you can butt to the fence? Gotta say, it has to be skewed almost 14.5 degrees in order to give a 1/8" error on a 4" cut - which is a VERY visible angle - almost an inch of skew...
Here's a thing to try: after setting the fence, take the piece you are about to cut, measure the cut, and scribe the line where the right side of the kerf should be. Now, with saw off, feed the piece the way you normally do up to the blade. If the line you drew does not match the right side of teeth, there is an error in how you measure either the fence or the piece.
LCHIEN
