Measure twice and still...
  • MilDoc
    Many time when I measure for cut on th BT3 it comes out a little (1/8-1/4") short. Here's what I do for rip cuts:
    1. Measure from the rip fence to the right edge of a blade tooth.
    2. set the fence.
    3. remeasure
    4. cut
    So the piece between the blade and the fence "should" be exact. Sometimes yes, sometimes no. Same for crosscuts since I use a block mounted to the fence for repeat cuts.
    The fence, SMT, and miter slots are parallel to the blade within the limits of my measurement (about 1/128").
    So, how do y'all do it????
    Mine always comes out pretty much dead on like about +/-.010" of the desired rip width. I check with my calipers.
    I can only suggest a couple of things to check:
    Make sure the rear of the fence is locked down so it doesn't deflect (actually that would tend to make it bigger, not shorter).
    or, make sure you use a good featherboard and or keep the workpiece tight against the fence, if you let it wander it will end up too narrow (what you seem to have) but omigosh, 1/4" is a lot.
    Or maybe your ruler is not held level with the table and tilts some - this would also cause the piece to be shorter/narrower than desired.
    • MilDoc
      Loring: actually, I check everything you mention. I hold the rear of the fence when locking it, I use a featherboard mounted 1/2" from the front of the blade and locked tight, and I use a triangular rule that sits flat.
      • Stytooner
        Roll Tide RIP Lee
        • 4301
        • Robertsdale, AL, USA.
        The triangle rule that I have doesn't actually start at zero. 0 is about an 1/8" away from the end. I know that sounds too obvious, but not sure what else could be going on.
          yeah but, Lee, if the end of the rule is against the fence and the extra 1/8 is there then the piece would be too wide... not too narrow.
          And I assume MilDoc, you use the same rule for measuring the ripped piece as measuring the blade to fence distance.
          The way I do it is to use a steel rule with "0" at the very end.
          I hold the rule level (parallel to) with the table but at the tip of the top tooth with the zero end of the rule butted to the rip fence.
          I do that rather than lay the rule on the table because the end of the rule wants to slip under the rip fence.
          I violate the same ruler rule but when I check with the calipers - dead on.
          • scorrpio
            • 1566
            • Wayne, NJ, USA.
            Almost looks like your ruler slips under fence a bit. I personally make all my checks with a combination square, moving blade flush with anvil, resting the anvil on the fence and measuring to the teeth.
            • monte
              ***** Windbag
              • 5242
              • Paw Paw, MI, USA.
              • GI 50-185M
              When ripping does your stock stay tight to the fence? How is your fence alignment?
              Monte (another darksider)
                Is it possible you are preventing the rear of the fence from moving into alignment as you lock the fence handle? I the final adjustment was done by moving the fence away from the blade, the end of the fence would be canted slightly toward the blade at the rear.
                • WEG
                  • 298
                  • Nahant, MA.
                  Hi MilDoc;
                  Boy, that's a strange outcome your getting...IF your fence is locked in place and you measure both the front and rear of the blade to the fence and it's right, you must be getting some movement in the wood as you are feeding it through. Did you ever remeasure after getting a cut that is 1/8 ot 1/4 inch smaller to see if the fence actually did move? On a very long shot here, could there possibly be something "loose" or worn with the arbor/shaft that could possibly allow some movement? Boy, I would think that much error couldn't be caused by arbor movement...just a thought. Please let us know what you find out, this is a good one!
                  Oh, one more.... are you sure the rails are really tightened in place? I'm really reaching here with these
                  WEG
                    Doc, try this experiment:
                    1. Lock your rip fence down somewhere. Don't measure, just lock it down any old place that's in the range of rip cut widths on which you're seeing this problem.
                    2. NOW measure, carefully, the distance from the blade to the fence as you normally do. Write that value down.
                    3. Make a rip cut as you normally do.
                    4. Measure the ripped piece and compare it to the value you wrote down, using the same measuring device for both.
                    This test should eliminate any errors introduced by the act of setting up for the cut. If the measurements match, there's most likely something going haywire when you lock down the fence. If the measurements don't match, it almost has to be your technique.
                    EDIT: Oooh, I just saw WEG's question about the rails. That's a good thought.
                    • scorrpio
                      • 1566
                      • Wayne, NJ, USA.
                      If the rails are loose, then pushing the workpiece to the fence would move fence AWAY from blade, resulting in a larger than needed piece. Not to mention that fence shifting during cut should result in a skewed rip, stalled blade and/or one heck of a kickback.
                      OP re-measures after setting the fence - which eliminates possibility of error during setting.
                      Indeed, if your piece comes out shorter than what you measured, re-measure fence to blade after the cut. If it is same as before, you are measuring incorrectly. Maybe you can describe in exact detail HOW you measure fence to blade? (I.e. how you place the ruler, from what direction/angle do you read it, etc)
                        Well, I guess we need a clarification from MilDoc.
                        I interpreted his statement that "Many time when I measure for cut on th BT3 it comes out a little (1/8-1/4") short" to mean that his setup measurement was shorter than what he actually got -- which would indeed mean that the fence is moving away from the blade. But on further review I now realize that his statement could be interpreted either way, and maybe he did mean the opposite of what I thought.
                          The only thing I can think of that hasn't been mentioned is discounted by the statement that the rip fence is parallel to the blade. Still, I think it's worth a double check. All that you have to do is to turn the saw off and put the piece you just cut up against the fence and next to the blade. If the blade is very close to the piece at the back and not the front, you are not parallel.
                          I set the rip fence position with a steel rule for short rips (less than 18 inches) and count on it being on the same side of the mark on the rule as I set - no measurable difference.
                          Another thing to check is to rotate the blade around by hand (power off, saw unplugged) and make sure each tooth of the blade is the same distance from the rip fence. If the blade washers are warped or something and the blade is actually trying to immiatate a wobble dado blade, it would produce the result described.
                          • MilDoc
                            Good suggestions. To clarify my post:
                            1. I use a steel ruler to measure rip fence and finished cut, has 0 at one end, no free room.
                            2. I hold it on edge so it can't slip under the fence (learned that one real fast) with 0" at fence, and measure to the right (fence)side of a tooth. I have measured front and back.
                            3. then cut
                            4. Say I want a 4" rip, sometimes I get 4", sometimes 3 7/8", never over 4", so cut is not quite wide enough.
                            5. I have remeasured after cut & fence is still at 4"
                            Based on suggestions made there are a few things to check. Will keep y'all posted! And thanks!
                            • RickT
                              • Jun 2003
                              • 175
                              Hi MilDoc,
                              How are you measuring the distance from the blade to the fence? 1/8" seems like a lot to be off, but are you jusing a tape measure? If you're pushing the end of the tape against the fence before the cut and then hooking the tape on the cut workpiece after the cut and the hook on the end of the tape isn't sliding to compensate for the thickness of the hook and the hook is 1/8" (which is pretty thick), then that could be account for the short cuts. What makes me think that you might be allowing the piece to drift away from the fence is that you said you "sometimes" get a cut that's as much as 1/8" short. If it's not all the time, then it must be technique. Anyway, keep us posted.
                              Thanks,
                              Rick
