David...in my construction applications I use the sawboard to cut sheet goods just about anywhere I can lay the sheet flat. Or sometimes I even cut with the sheet upright but I'm not recommending that. Most of the time I use saw horses with a couple of sheets of MDF across them (if they aren't stacked full of constuction debris) and then put the sheet to cut on top of that. If the cut is near the edge of the sheet I will hang it over the MDF and if the cut is nearer the center of the sheet I will usually part the underlayment of MDF sheets and cut the top sheet btween those.No reason you couldn't do it on the floor with 2" foam if you wish. HTH
