Favorite TS Blade Poll
  • vaking
    • 1428
    • Montclair, NJ, USA.
    • Ryobi BT3100-1
    #31
    Larry,
    This is the confusing place:
    "However, it also pointed up just how good the BT's stock blade is. Is there a difference between crosscuts made on the BT and the Forrest-equipped Delta? Yes. But as Loring says, the difference is pretty small. (Note that I'm speaking only to crosscut quality here. Comments about ripping wouldn't be fair or meaningful, since a CMS can't rip.)"
    Isn't this a comparison of 36T vs 80T?
    You are correct about WWII being 40T general purpose blade - my mistake. Loring's conclusion was right on - WWII is probably a notch better than ryobi stock blade but at a $100 cost - this is not the first upgrade you want to make. If you want a better quality crosscut - get a dedicated crosscut blade.
    Alex V
      #32
      Ah, okay, I gotcha. Yes, it is a comparison of the stock 36T Freud/Ryobi combination blade and the 80T Forrest crosscut-specific blade. And you are correct that strictly speaking, it's not really a fair comparison.
      However, that was exactly the point I was trying to make. Loring reported that the difference between the stock blade and his 40T WWII was pretty small. I added that the difference between a crosscut made with the stock blade and one made with the 80T Chopmaster is likewise small. In either cutting mode, the stock blade stands up well for itself -- even in an unfair comparison to an expensive crosscut blade like the Forrest Chopmaster.
      I am inclined to agree with you that a WWII is not a priority upgrade since the actual return on one's investment may not be enough to justify the cost ("inclined" because I don't own a WWII, so I can only go by what others have to say). But I would add that based on my experience with the Chopmaster, upgrading to a dedicated crosscut blade is equally questionable. If someone drops big money on a crosscut blade expecting miracles, IMO they're going to be sorely disappointed. The BT's stock blade is really pretty darned good.
        Kind of eachoing Larry's point.
        If you have a Ryobi blade and you feel you have problems with your cut, like burning, saw marks, wandering, splintering etc., don't buy a Forrest or other expensive blade and expect all to be cured.
        The Ryobi OEM blade is quite good, if you have the aforementioned problems then you probably need some saw tuning.
        The Forrest is an incremental improvement in smoothness of the cut, reduced splintering perhaps, but at a geometric increase in cost. You'll also get a better made blade and thicker carbide but the those really don't translate into better cuts in the short term.
