Sofa (recliner) table
  • tlt
    • 125
    • Tucson, Arizona.
    • Delta 36-682
    Shep -- I've heard about people filtering with a cheese cloth or a coffee filter. I initially tried the coffee filter method myself, and it backed up really quickly and I ended up with a big vinegary mess all over the place! If you try it and have some luck, I'd love to hear what worked for you. A cheese cloth is probably the way to go...For me, the "clean up" wipe down is a chance to make sure I didn't miss any spots sanding.
    Big Tim -- I've used aniline dyes and they work great and give you control over the color. But if you're going for an ebony finish, this method is dirt cheap and an easy way to match other pieces I've made before.
    • Rand
      • 492
      • Vancouver, WA, USA.
      It looks great.
      It looks like it would be easy to knock over if you hit it with your elbow while sitting in the recliner. Is it?
      Thanks for the tips about ebonizing.
      Rand
        That looks great! 90° from the ones I've made but for a chair I don't see how you could do anything different. Was that your idea or have you seen others that were wide rather than long. An example of what I'm talking about.
        • tlt
          • 125
          • Tucson, Arizona.
          • Delta 36-682
          Rand - That's them physics I was confused by So far, so good. You wouldn't think so, but between those little tabs behind the vertical uprights and the way it wedges underneath the chair, it's actually much sturdier than the TV tray I was using before. To make it even more sturdy, you could replace the frame on the bottom with a solid (heavy) base.
          Black wallnut - The width/length proportions for the top were my own idea. And your couch table was one of the designs I used for inspiration -- thanks!
          • Norm in Fujino
            • 534
            • Ryobi BT-3000
            Originally posted by tlt
            . . . it represents what I love most about woodworking -- the ability to custom fit a project to your needs. The table was ebonized using the vinegar and steel wool method, and finished with General Finishes poly/oil blend.
            Ain't it great to be able to make a piece for a spot of specific dimensions? Yours is a great example. ..and I love the ebonized finish; I'll have to try that.
            • ironhat
              • 2553
              Very nice design. Consider it stolen (the sincerest form of flattery, etc, afterall!), but the talent? Could I get a loan on that?
              Blessings,
              Chiz
