A few Projects done during my absence
  • Sawduster
    • 342
    • Cedar Park, TX, USA.
    Cabinet man said I should post some of the stuff I've done over the last while, so here goes,
    Here's a pulpit lecturn I made for our Church. The rails holding the panels in the front were steam bent, my first attempt at that. Cut the tenons and the grooves for the panels prior to bending.
    Made this box to hold some of my machinest instruments and my good combo squares.
    With the lid open and tray visible.
    And with the tray removed.
    Hand cut secret mitered dovetails for the corners.
    Here's a birds eye maple and walnut chess box.
    A gateleg drop leaf table of walnut.
    and a bunch of shadow boxes I made for some troops serving in Iraq.
    I got some curly pecan from a mill near Huntsville, TX and made this table from some of it. The front of the skirt is a bent lamination.
    and made this cabinet from more of the pecan. The doors a coopered. I added a few accents of mesquite for the knobs and breadboard ends on these last two pieces.
    Jerry
    \"Those who expect to reap the blessings of freedom must, like men, undergo the fatigue of supporting it.\"
    ~ Thomas Paine ~
    http://www.sawdustersplace.com
  • bmyers
    • Jun 2003
    • 1371
    • Fishkill, NY
    • bt 3100
    Nice work! I really like that curved entry table. Gonna have to put one of those on my list.. Thanks for sharing.
    • jking
      • 972
      • Des Moines, IA.
      Nice job on all of them. Were the shadow boxes something you did through your local service branch?
      • Sawduster
        • 342
        Actually, a Colonel in the unit over in Iraq posted on another WWing forum asking for someone willing to take on a commission job to make some plaques to be given to some of their soldiers. I responded and offered to do the work for my cost of materials and shipping. Discussing the details of what they wanted I determined that material wise, I could make the shadow boxes for the same material costs as plaques. Including $10 for shipping, I had around $21 in each one, and he sent me an extra of each of the items inside, including the Soviet bayonet and an engraved brass plate with my name to make one for myself. The wood is cherry and I used that clear plastic for the "glass".
        Jerry
        ~ Thomas Paine ~
          Nice stuff, Jerry. I may have to pester you down the road on the steam bending.
          • oakchas
            • 432
            • Jefferson City, TN, USA
            very nice! all of it wonderful... I hope to do as well on casework someday.
            Love the curved fronts
            • TheRic
              • Jun 2004
              • 1912
              • West Central Ohio
              Nice work on all the projects. I can tell you have been busy. I like the drop leaf table the best.
              Ric
                Nice work Jerry. Your craftsmanship shows. So, no tailed tools on these? I like the "secret mitered dovetails", they are cool. Too bad they won't show. Use see through wood next time.
                • Sawduster
                  • 342
                  Tailed apprentices were used as needed. I do most of the joinery by hand, DTs, M&Ts, etc. I'll have to see if I can track down someof that see-through wood.
                  In the olden days, very much of the joinery was hidden. Looking at drawers of very old pieces you will see a large variance in cleanness of the DTs, for instance. They were there for the strength of the joinery. While an occassional DT might be seen on the outside of a case, much of the work like that is covered up.
                  The drop leaf table is one of my favorites, also. One of the few pieces I've made using someone else's plans. This one was from a collection of plans made from original pieces from earlier times that Tools for Working Wood carries. The plans themselves are minimal in nature with a pattern for the cabriole legs and mostly just drawings with measurements. I did the rule joint (or Table Joint as it is sometimes called) with a matched pair of vintage wooden table joint planes. I also happened upon some air dried walnut that I used for the table. Had to buy some store bought for the thicker pieces for the legs, so the color is not as good on the legs as the other pieces.
                  Jerry
                  ~ Thomas Paine ~
                  • Knottscott
                    • 3815
                    • Rochester, NY.
                    • 2008 Shop Fox W1677
                    I really like that pecan table....is it your design?
                      Very nice.
                      • Sawduster
                        • 342
                        It is my take on a fairly classic piece. Many of the pieces I've done recently have started off as wanting to try a technique I hadn't done before. I had done another piece with a smaller laminated bend but I wanted to try a larger one and add in a drawer whose front grain matched. I fiddled around for a bit and came up with that idea.
                        Our Church just recently finished our building and I volunteered to make the pulpit. That gave me a chance to try out steam bending.
                        Jerry
                        ~ Thomas Paine ~
                          It looks like you have been busy. That is some very nice work.
                          • bigstick509
                            • 1227
                            • Macomb, MI, USA.
                            • Scot
                              • 34
                              • Ottawa, Canada
                              • Ryobi
                              Great work and a wide range of designs. I want the gateleg table
                              Art
