Your craftsmanship looks good in spite of the color. I'm not a big fan of red tones either but sometimes it deos look good.
Pie Safe Done
LOML would like that. And so do I. Nice work.
EdDo you know about kickback? Ray has a good writeup here... https://www.sawdustzone.org/articles...mare-explained
For a kickback demonstration video http://www.metacafe.com/watch/910584...demonstration/Comment
Hehe...actually I think she is going to use them to house tea...hence the asian influence.
I LOVE my grizzly tools. I have a Grizzly left tilt cabinet saw, 14" band saw w/riser block, disc sander and of course the 8" jointer you see in the picture.
I would highly recommend each one of those. Some of the stuff Grizzly makes isn't great, but the stuff I have is awesome. You just have to do your research. Like I wouldn't buy a lathe from them as their lathes kinda blow. I would go Jet or if you had money to burn Oneway.
Someone asked what finishing procedures I used, so here they are.
-I sanded to 320 grit.
-Sprayed the piece with two or three coats Target Coatings USL (very nice lacquer) to seal it. lightly sanding with 320 in between
-Sprayed about 3 coats of that red paint in light coats...the paint was 100% acrylic...sprayed beautifully
-Sprayed 2 to 3 coats of Target Coatings Superclear polyurethane as a top coat...scuff sanding with 320 in between coats if neededComment
I almost forgot to mention on the finish. I used some retarder in each of the liquids and that helped thin the paint a little to make it sprayable.
I got most of my finshing supplies from http://www.targetcoatings.com/.
They have very high quality nice stuff.Comment
