Jig saw attachment
  • colomoose
    Handtools only
    • Sep 2014
    • 2
    Jig saw attachment
    Looking for jigsaw attachment kit
    • 22028
    I have a complete router mounting kit.
    There were two kits, one kit with two plates, one for router and one for jigwaw.
    The other kit only had the router plate.
    Mine is the one with two plates.
    I'd like to keep the router mounting plate and related items.
    Would you be interested in the kit less the router plate and filler rings but with the jigsaw plate and all the fence items?
    Its actually quite possible to mount a router to the jig saw plate if you wanted to use a router,Click image for larger version  Name:	image.png Views:	0 Size:	1.56 MB ID:	860283
    In the above pic I would keep the plate on the right and the red rings.
    Click image for larger version  Name:	BT3000 Router accessory kit.webp Views:	0 Size:	115.9 KB ID:	860284
    You get all the other hardware except the red rings and the one plate.
    You still have the option to mount a router later, it requires 3 drilling holes to mount most routers; the four hole in the plate I keep are only for the Ryobi routers of the day.
    Do you have any other suggestion? If you are only using the jig saw then the fence attachments are not much use to you.
    • colomoose
      Handtools only
      • Sep 2014
      • 2
      Yes you keep plate and red rings. How much?
        • 22028
        Lets take this to this forum's private mail... look for a message there.
        • Jim Frye
          • 1345
          • Maumee, OH, USA.
          • Ryobi BT3000 & BT3100
          Here's mine. Note the vac port. And an article link for the build.
          https://www.sawdustzone.org/articles...-jig-saw-mount
          Jim Frye
          The Nut in the Cellar.
