Bought this saw used 3 years ago. I cut 3/4" MDF almost exclusively. Used it the first year with no problems on 3/4" MDF. Pulled it out last year to use it and it can't get more than 6" into a cut of the MDF without losing significant blade speed and bogging down during the cut. Tried multiple times to make sure it wasn't binding on the fence. I'm not using the blade guard so it's not binding there. I thought the blade was the issue so I had it professionally sharpened, yet the issue persists. Put it away lat year frustrated. Just took it out again today and still having the same issue.
This is clearly a saw problem as it worked fine for one season. What can I do to fix this? Could it be a belt problem? If it is a belt/etc what is a good place to source parts?
Thank you in advance.
twistsol
LCHIEN
