Hi folks. Some of you old timers might remember that I was a frequent visitor to the old BT3 Central group years ago. After a long absence, I've dusted off my trusty BT 3100 and decided to see if I could upgrade the router table section with the type of capabilities you find on modern router tables, hopefully incorporating a router lifter and a high quality fence. I assume the solution would be to replace the current aluminum plate with either a cast iron or MDF/melamine table top, but I have no idea if that's a realistic possibility. I knew that the people in this forum have probably discussed this topic and maybe met this challenge many times in the past, and would appreciate any pointers and referrals you can offer.
Thanks, and it's great to see that many of my woodworking friends from the mid-2000's are still here.
Jeff
Jeff
LCHIEN
aiyou
