Need to change the blade....
  • akronee
    • Dec 2011
    • 36
    • Denver, CO
    • Craftsman 315.228110
    on my Craftsman 315.228110 but my arbor wrench is nowhere to be found. I stuck a screwdriver down there and got it changed but I need to replace the wrench for a regular solution. Found where to buy the wrench at searspartsdirect, but shipping is a little much. I figure I can just build my own, but I can't get my caliper jaws down on the arbor. Anyway, can someone who has a 315.228110 measure the inside and outside dimensions of their wrench, or if someone knows off the top of their head what these dimensions are, I would very much appreciate it.
    Thanks!
    • 22039
    the arbor nut wrench is 3/4" The nuts for the riving knife are 1/2". ANy open end or closed end box wrench will do. an box end 12-point with an offset is ideal for those.
    The arbor lock wrench I don't remember offhand but it has to be very thin and narrow to fit behind the blade into the given slot and almost requires the wrench that comes with the Ryobis (or Craftsman).
    Using one of those blade grabber tools, you can get the blade off with just the 3/4" box wrench, if you start and tighten the nut by hand when using the blade grabber, then you mau be able to tighten it up with the 3/4" wrench, too.
    • jdon
      • Feb 2010
      • 401
      • Snoqualmie, Wash.
      The arbor lock wrench is also 3/4"
        • 22039
        that's probably right but the other trick is that the outside must also be a certain dimension as well as the overall thickness. At least to wrok right.
          Tappet wrenches come in most sizes, and are very thin.
          • akronee
            • Dec 2011
            • 36
            • Denver, CO
            yeah, so if the inside diameter is 3/4, what's the outside dimension of the wrench? I have some .080 steel stock that I thought I could cut a tool out of.
            • bodier62
              • Aug 2011
              • 8
              • Carrollton, TX
              outside dimension
              outside dimension is 1.25"
              • akronee
                • Dec 2011
                • 36
                • Denver, CO
                Thanks so much!
                • woodyb
                  • Apr 2012
                  • 7
                  I have always just used the throat plate behind the blade to hold the blade still while I use the wrench to loosen it.
                  then to tighten, I use the wrench on the nut and let it move down until it is against the table and then just pull on the blade carefully to tighten it.
                  works just perfect. the blade will be tight enough but you do have to be careful not to slip and cut yourself on the blade.
                  robert
