blade adjust bt3000
  • lum747
    • Mar 2013
    • 25
    • huntsville texas
    • ryobi bt3000
    blade adjust bt3000
    ryobi bt3000 is there any way to adjust the blade to be at 0 degrees , other than the screw adjust in the front of the saw, my saw will not go to (0) degrees with the adjust on the saw, abour 3 degrees off, but asjust will not go any further to the right any suggestions?
    • 22085
    i think there's a couple of stops that set the 0 and 45 degree positions to be accurate.
    THe stops are bolts with locknuts to lock their position if i remember correctly.
      • 8803
      Those "stops" are behind the front panel, so you will have to get under it to make adjustments. Blow it out good before getting under there.
      • lum747
        • Mar 2013
        • 25
        • huntsville texas
        • ryobi bt3000
        blade adjustment bt3k
        i took the bolt completley out of the threded bracket and still will nt go to a true 45 from the table, seems the gear and bracket it rides on looks to be mounted a little too far to the left, so is there a way to maby like raising the motor assy up a few degrees, maby put a shim in the motor mounting assy somwhere?
          • 22085
          first I've ever heard of something like that. Usually the stop can be adjusted to let you go beyond 45 a little bit.
          Does the scale also show it being shy of 45? If so I'd say something besides the stop is blocking it from ful travel. If it shows more than 45 but you are measuring less than 45 then Id suspect that the frame is bent or something is mismounted or your 45 reference is bad.
