13 amp motor questions
  • tropicalarcadian
    • Oct 2012
    • 15
    • South Florida
    • Ryobi BT3000 13amp
    i just purchased a 13amp model since i didn't know any better. Now that it's too late, can i wire the motor for 220v? Do i need to buy a 15amp motor if i'm going to be ripping 3 inch hardwoods? Thanks.
  • toolguy1000
    • Mar 2009
    • 1142
    • westchester cnty, ny
    with the proper rip blade, feed rate and aligned rip fence, a 1hp motor will be sufficient to get the job done. doing it in 2 passes (1.5" first pass, 3"+ second pass) would reduce the strain placed on a saw motor. IMHE, power is customarily accorded more importance than necessary.
      The Ryobi motor may not be rewired to 220v. If you are going to rip 3" hardwoods plug the saw into an outlet on a circuit with no other loads on it at the time. Use a good quality sharp rip blade and feed only as fast as the saw can cut. If the saw bogs down use a cut down riving knife and cut it in two or more passes. If the saw has problems then you might try to find a used 15 amp motor from someone parting a saw out. If your primary use for this saw is ripping of 12/4 hardwood you might be better served with a different saw.
        • 9568
        I do not believe either the 13 or 15 amp motors are capable of being wired 220V, but I could be wrong. Check the manual. (I am firewalled from getting the URL for you, but Google it...)
        As far as ripping 3 inch hardwoods, I guess it depends on what hardwoods you are ripping... I have ripped 12/4 (?) pin oak on my 15 amp BT3100 and thought it more than sufficient. Just used a good, sharp 24t ripping blade and a reasonable feed rate.
        I put the (?) there because I didn't measure out the thickness. It was a slab I cut from a downed tree and slabbed on my bandsaw. I planed it to whatever thickness, I don't recall, but it was somewhere close to that...
        The blade I was using is a Freud Diablo 24T ripping blade from Home Depot.
        If you are going to rip / resaw 12/4 a lot, like Black Wallnut said, you might want a beefier saw, or to resaw on a band saw...
        And I totally agree, you need to make sure the circuit the saw is running on is ONLY running the saw... You do not want to starve the motor for amps when running it that hard.
        • Knottscott
          • 3815
          • Rochester, NY.
          • 2008 Shop Fox W1677
          If you're talking about a 13 amp "BT" motor, running it on 220v would likely result in running at double RPM for a matter of seconds (or less ) before it goes up in smoke.
            BT3s cannot be "wired" for 220V unless you've got one of the (very rare) 220V motors produced for overseas. Not convertible and besides, you'd not have a motor any more powerful! Its a misconception that 220V is more powerful - a 1 HP motor is 1 HP whether its 120V or 220V. With residential 120V supply, motors are limited to about 1.5 HP because of the current limit. With a higher voltage they can make the motor bigger and more HP and not run out of current but that's a different thing.
            Like the other said, make sure the power wire to the saw is preferably direct, if you must a 12 ga extension cord (short) CAN BE USED. a sharp 24T ripping blade, thin kerf. This is all to get your saw running most efficiently.
            thin materials are generally easy. As the material gets thicker and harder, you have to feed more slowly or the blade will stall. Feeding too slowly will burn the wood. When you get to the point where it burns at the fastest speed you can manage then you are out of power.
            Still as others have mentioned, do it in two passes, or rip 1/16th oversize, let it burn a bit, then rip to exact size with a shaving rip operation to clean off the burn marks.
            If you plan to do this often, you will need a bigger saw.
              If a motor has dual voltage options (120/220) the ID plate would have the wiring diagram. The horsepower would be the same. At 220V the amperage draw would be half than if run on 120V. For difficult rips, a thin kerf blade, as low as 20T could be used. Cuts may be easier if done with the blade run higher than just tooth/gullet exposure.
                The BT3000 has a universal motor. Universal motors are simply not made with multiple parallel-series windings like induction motors that allow dual voltage use.
                The OP clearly stated he has a BT3000 with the early 13-Amp motor. Changing motors is ridiculous, people have been asking to change motors in BT3 in the 12 years I've been associated with this forum and no one has yet reported doing so successfully - it would be a technical challenge.
                You can't raise the blade much higher if you are already doing a 3" rip as the OP suggested he wants to do.
                  The BT3000 has a universal motor. Universal motors are simply not made with multiple parallel-series windings like induction motors that allow dual voltage use..
                  I didn't specify a BT motor. Motors can be replaced.
                    Suggestion to rip in two passes (different blade heights), or flipping over, isn't as effective as a single pass, IMO.
                      Let's not over think this. This section of the forum is for BT3x saws. I think it is fair to assume that when a thread is in this section that the OP or a staff member placed it here due to the saw in question being a BT3x saw. Because of that suggestions of two passes is a valid option and gives great results when performed correctly. Also for what it is worth the BT3X saws have more depth of cut than any 10" cabinet saw, that does not mean it is always best to use it all.
                      • tropicalarcadian
                        • Oct 2012
                        • 15
                        • South Florida
                        i will be ripping 3" hardwoods to use on a Craftsman Router Crafter, so two passes will suffice for that purpose. And the shaving rip operation is one of those "Why didn't i think of that?" ideas. So thanks for the help, i'll make due until i can find a 15amp motor.
                        Still as others have mentioned, do it in two passes, or rip 1/16th oversize, let it burn a bit, then rip to exact size with a shaving rip operation to clean off the burn marks.If you plan to do this often, you will need a bigger saw.[/QUOTE]
                          just don't let the motor bog down too slow even before it stalls. if it does, you will surely burn out the motor with prolonged use. You can hear it laboring and this is really, really bad for motors, any motors, not just the one in this saw... The BT3's don't have a thermal cutout to my knowledge. If you see smoke or smell burning electrical insulation, it's too late. But don't worry too much, there's not a whole lot of difference between 13 and 15 amps.
