was the motor smoking or the wood smoking?
Motor smoking is clearly a sign of overloading the motor - could be dirty as suggested.
A 24-tooth blade will help a lot - among other things its spcifically for ripping and has large gullets between the teeth so that wood chips (actually shavings when ripping) won't fill up the gullet and keep the blade from cutting efficiently.
Again, smoking motor = feeding too fast, smoking wood=feeding to slow, cherry is prone to burn more easily then other woods. 6/4 hardwoods should be handleable by the bT3 though.
