Need Parts List for Wide Table & Legs
  • Herman
    • Jul 2010
    • 6
    The sued BT3000 I recently bought came with a big pile of Ryobi options. I managed to sort out the parts for the long miter/rip fence and the router attachment kit.
    It looks like I also have a wide table kit and the factory legs for it, but I don't know what parts I might be missing or how to install it. Does anyone have a parts list or user manual for these options?
    Thanks
    I've got the manuals for the Long Rip Fence, and the Leg Kit. I thought I had one for the Wide Table Kit.
    I think The Wide Table Kit basically consists of 12 stamped T-nuts (maybe more), bolts and washers. 8 of them are for the 4 square steel connecting plates (the long fence has 2 plates with chamfered corners). 2 square plates per rail, one on the bottom the other on the inside. There are at least 4 L-brackets and screws for installing an insert table between the rails.
    I'll see if I can get my scanner working and upload the manuals.
    Here's the Leg Kit manual:
    http://www.alr6x6.com/pelligrini/BT3...it_4730305.pdf
      • 9542
      On mine, the wide table setup consists of...
      Extra set of rails, Rail connectors. Basically metal plates with holes to pass bolts through, Bolts and tee nuts. (16 if I remember right), Leg set which is a pair of legs, a two piece spreader, adjustable feet, carriage bolts, nuts and washers.
      I believe there is a wide table top available, but it isn't part of the kit, I could be wrong. Most guys shop make theirs...
        Yea, it was the Air Floatation/Vacuum Clamp Table for use with the Ryobi 28 Gallon Dry Vacuum.
          • 22040
          Yes, that was the only table top Ryobi sold.
          Most people made their own; it was not hard and you already had the four L-brackets included with the wide table (rail) kit.
          The flotation/vacuum table was not real popular, there are not that many out there.
          The description of the contents of the kits others posted are about right except:
          Rail kit: Two rails (F&B) 16 bolts/T-nuts and four four-hole metal strips for concatenating the rails and four L-brackets plus four bolts and four more t-nuts for attaching the table top.
          • Lonnie in Orlando
            • 649
            • Orlando, FL, USA.
            Welcome to the forum, Herman -
            The "Legs" and the "Wide Table" were two separate kits.
            Erik posted the link to the "leg" manual. Here is a link for the Wide Table manual ...
            http://dl.owneriq.net/c/c71332c6-625...d3b4d073bb.pdf
            Good luck on with your installation.
            - Lonnie
