Miter Fence - how to add fence additions...?
  • Jack Beale
    Handtools only
    • May 2010
    • 4
    • Florida - near Sarasota
    • BT-3100
    I have a BT-3100 and am very pleased with it as a homeowner tool -- accurate, versitile and won't rust here in FL.
    I'd like to add a fence to the BT miter fence to accommodate sliding additional fences (L/R) and things like box finger jointing apparati.
    I"m reluctant to start drilling holes in the existing fence. Can anyone point me in the right direction to get some tips on what others are doing, please...? I've searched the BT3Central fourms without locating helpful and I've done general Google searches without success as well.
    Thanks for the tips...
    Check out t-nuts.com, be sure to follow the link at the top of the main forum page here. They carry some small square nuts that fit into the slot on the face of the fences. There are some hex bolts that can fit the slots too.
    There's a few photos of my woodsmith box joint jig on my miter fence in this thread. http://www.bt3central.com/showthread.php?t=50102 There are two machine screws that go into the small t-nuts on the fence through the attachment block, then the jig attaches to the block.
    Another option is using fence clamps like the ones in this review: http://www.bt3central.com/showthread.php?t=49791
      Welcome to the forum and congrats on your new saw! Private message (PM) Loring for his excellent .pdf reference on this saw. As for the fence, it is slotted to accept t-nut style washers that have machine screw threads attached (as posts or separate) that you can use to attach auxiliary materials to the fences (both miter and main fence) I am sure others will chime in here with there experiences shortly. Again welcome
      • Jack Beale
        Handtools only
        • May 2010
        • 4
        • BT-3100
        Tx chopnhack
        Thanks for the welcome.
        I'll have to admit that the saw is not "new". I've owned, and used, it for several years.
        Right now, I'm into someting called "torsion boxes" that require a vertical half-lap joint. When you have half a dozen pieces in each direction (imagine an egg-crate here), cutting accuracy gets important.
        The jig I built is more of a "shop-aid" - I want something better.
        • Jack Beale
          Handtools only
          • May 2010
          • 4
          • BT-3100
          pelligirni -- thanks...
          The www.t-nuts.com is very promising...
            • 22098
            this page on the t-nuts website is always a little bit hidden to me... but explains what nuts from his site you need for the different positions on the BT3x saws.
            http://t-nuts.com/prod.shtml
            the small nuts on the right fit the SMT front side slot; there are also nuts for the top slot and back side slot.
