Oshlun 6" stack Dado or Freud 6" Stack Dado?
  • headhunter636
    • 161
    • Federal Way, WA
    • Ryobi BT 3000
    I've decided to get a 6" dado instead of an 8" for my BT3000. Has anyone tried either of these dado sets, and if so, what would you recommend?
    Thanks.
    Dave
    BT3000
    "98% of all statistics are made up"
  • gary
    • 893
    • Versailles, KY, USA.
    I've used the Freud SD206 while I had my BT3. I've no complaints on how it cut at all. The arbor on my BT3 would require the outside blade rest on the threads when using 3/4" width and would sometimes give me an uneven cut. I can't blame the blade for that.
    Gary
    • Charlie
      Banned
      • Jul 2009
      • 210
      Deleted by me.
      • Knottscott
        • 3815
        • Rochester, NY.
        • 2008 Shop Fox W1677
        Freud makes 3 or 4 dado sets, but I'm assuming you mean the entry level SD206 that's priced closer to the Oshlun (formerly Avenger)? It's readily available and is very popular. It'll be difficult to find people who've tried both.
        I owned the 8" version, Freud SD208 for over 2 years and liked it...it's a good set and is well made. The Oshlun is a copy of the $300 Systimatic set, and also gets good reports from owners plus has the advantage of having quite a few more teeth....5T chippers vs Freud's 2T chippers. I own the 8" Systimatic 42T/6T set, and find it to be excellent. All things being equal, more teeth typically equates to a cleaner cut, but it's hard to say if the Oshlun is made to high precision standards. I've tried an Oshlun 40T blade and found it to be surprisingly good for the price and also surprisingly well made...large C4 carbide, heavy steel body, highly polished brazing, etc. The SD206 is always a safe bet as a solid performer, but I suspect the 6" Oshlun may have more upside potential by design.
        Here's a look at the 8" Systimatic set that the Oshlun mimics.
        • sweensdv
          • 2873
          • WI
          • Baileigh TS-1040P-50
          Something you might also want to consider is the weight of those sets. On wider dado cuts the Oshlum, with its full plate design for the chippers, will be considerably heavier than the Freud. This extra weight will cause the saws motor to work a little harder on start up.
          My first dado set was an 8" Harbor Freight set, #44566, that is similar in design to the Oshlum. I would quite often trip the breaker on start up when cutting wider dados. I purchased the Freud SD206 set and haven't trip a breaker since.
          • luteman
            • Dec 2007
            • 145
            • Northern Michigan
            I have the Oshlun 6" for my BT3100. Works just fine. Quality of cut is very good for its' price point.
              I use the Freud SD206, and have been satisfied with the results.
                I have the Oshlun and use it FREQUENTLY for full 3/4" dadoes. Great set for a steal of a price, especially if you get it on sale.I would whole heartedly recommend the Oshlun...
                  I have the Oshlun (Avenger when I bought it) and it has been fine for me. From what I hear the Freud is also a good set so you cant really go wrong with either.
                    • 22106
                    Gary, I think that if you take off BOTH arbor spacers (there's a 1/2" and a 1/4")
                    then the full stack of the 6" dado (all 13/16") will fit on the arbor without any blade plates resting on the threads.
                    The 8" dados give the problem you state; the larger diameter outer plate will hit part of the saw body on the right if both spacers are removed. If the 1/4" spacer only is left then the blade will avoid hitting the body but only 5/8" stack will go on, any more and the leftmost plates rest on the threads leading to uneven cut as you describe.
                    I know, I own both SD308 and SD306 sets.
                    • Sawatzky
                      • 359
                      • CA
                      I also have the Freud 6 inch set that I use on my Ridgid contractor saw. It works great.
                      • jaybee
                        • 157
                        • Regina, SK, Canada
                        Being a poor canuckian, I use:
                        Mastercraft 6-in. Dado Carbide-tipped Circular Saw Blade
                        Product #55-1014-2
                        Reg. $69.99
                        purchased on sale for much less. Loml is quite proud of the tv stand I made using it to make the cuts in the legs for the shelves. I got my money out of it on that project alone.
                        I saw the WA and figured you might be able to sneak across the border when it goes on sale again. (not if, but when - everything from Canadian Tire goes on sale, you just need the patience to wait for it.)
                        • jhart
                          • 1715
                          I have the Avenger (Oshlun) and it does a very good job the times I have used it. For most dado's, I use the router about 90% of the time. Just easier to set up than the Avenger.
                          • pbui3057
                            • Jul 2008
                            • 114
                            • Mather, CA
                            I owned the Skil (lowes) cheap dado set. That was the worst thing I had ever seen. I then purchased the Freud SD506 off of ebay for about the same price as SD206. I loved that dado set. I ended up selling it when I sold my BTS21. The dado bottoms were perfectly flat. I then bought the Oshlun after hearing some very good reviews from everyone here. I think that the SD506 was better and cut cleaner than the Oshlun but the Oshlun was considerably cheaper new vs new. The used SD506 I got off of ebay actually looked and felt in good condition. It came in a plastic box and had everything in there.
                              I also had the unfortunate experience of owning the Skil 6" set. Lousy piece of junk...
                              Comparing the Oshlun with the SD506 isn't exactly a fair comparison... The SDS0630 is comparable to the SD206.
