I am having difficulty raising the blade. The blade moves down easily but will not move back up. Do I need to clean sawdust out of or lubricate the parts where the motor slides up and down? When I try to raise the motor, it seems to tilt toward the back slightly and appears to wedge in place. When I apply pressure from the bottom, it will move up when I rotate the handle. Is there some adjustment or maintenance that needs to be done?
What do I need to do to make it raise up easily?
LCHIEN
