Craftsman 21829
  • jeepman71
    • Nov 2008
    • 138
    Craftsman 21829
    Hello all, i am new to this forum and have recently purchased a Craftsman 21829. So far i am very happy with the saw, the people at Sears had miss marked the sale price and i got it new for $189.00.
    The reason for my thread is not to wag the tongue about the price but because Craftsman no longer makes the throat plate for a dado blade. In searching around I find that it is very similar if not exactly like the BT3. I have had no luck finding much information on this saw(BT3) so I don't know if the plate is still available for it or not. I also don't know if it will fit the 21829.
    Any informaion you can give me would be greatly appreciated.
    • 8694
    I am sure some of the other readers will have the answer and I think it can be ordered from Sears but I don't know what number to order it under.
    But I do want to welcome you to the forum! Best cutting inexpensive saw around!
    • BobSch
      • 4385
      Here's a dado TP on EBay
      http://tinyurl.com/5v5pcp
      Bob
      • Tom Slick
        • 2913
        • Paso Robles, Calif, USA.
        • sears BT3 clone
        just make your own. If you can't let me know and I'll make one for a small price.
        you'd be better off with a zero clearance tp. the factory dado plate leaves a huge opening
          • 21765
          They're not hard to make - at least they have square corners unlike Deltas and other big saws :-)
          I think details are in the articles section here.
          You can also buy them as accessories, the Sears 21829, 22811, the Ryobi BT3000 and BT3100 saws all used the same castings and basic design so the throat plates will be all interchangeable.
          Home made ones in 2-3 sizes to fit a range of dado sizes will probably work the best...
            Welcome to the forum Jim,
            I concur with the OPs, making your own is the best way to go, its not that difficult. Once you have the first one perfect create a template and then you can make them in batches. You will find a huge improvement using a ZCTP for each blade and bevel you use regularly. You can use a wide variety of materials, wood, lexan, laminate flooring, corian etc.
              What about the T-nuts link on this homepage? Don't they still sell the good zero clearance inserts?
              • jeepman71
                • Nov 2008
                • 138
                Thanks Gentlemen, i went ahead and bought the plate on Ebay along with a couple blanks. From these i will make my own blanks for future use.
                On a side note like so many other forums i have wasted time in this forum is awsome. I plan to visit more in the future.
                Thanks
                • cwithboat
                  • Jan 2008
                  • 614
                  • 47deg54.3'N 122deg34.7'W
                  • Craftsman Pro 21829
                  Yes. I recommend T-Nuts.
                  Welcome to the clan Jeepman
                  regards,
                  Charlie
                  Rudyard Kipling
