The motor burned out on my BT 3100 table saw. I live in Central Florida. Does anyone know where I can purchase a replacement motor?
Need to replace the motor on my BT3100
new motors from Ryobi or their distributors will run you about $180 or so.
best bet is to wait patiently - used motors from parted out saws will run you around $50-60 and can be found in the classifieds here and on eBay. Sometimes whole saws in modest condition/missing parts can be found on Craig's list for under $100.
remember, motors from BT3000, BT3100, and Sears 22811 saws are pretty much interchangeable.
BT3 FAQ - https://www.sawdustzone.org/forum/di...sked-questions -
need to replace motor on my BT3100
Have you thought about having the motor repaired? I would check into an electric motor repair shop in your area. They may be able to rebuild/repair your motor cheaper than buying a new one. Just a thought...might save a few bucks here and there .........eezlockComment
That suggestion has been around a while and is in the FAQ. But has anyone successfully done that? I don't recall hearing it done or a price.
If
If you do attempt this you need to call motor shops and tell them you have a 15A universal motor that needs rewinding and see if they can do it and for how much.
The motor is "trashed". There were most of the armature was in pieces inside the housing when I took it apart.Comment
I don't think it is repairable. The amature is in pieces and no longer attached to the shaft.Comment
LCHIEN
