Finally, my mobile stand is finished and I was about to unbolt the 21829 from its cart and put it on.
But I've got one last question. I made the top so it just sets into the frame without fasteners (was it Rod's old mobile BT cabinet that had the removable piece of MDF?)...supported by triangular brackets at the corners and cleats on the sides.
I suddenly wondered if there is a downside to not putting the saw on an open-type frame so the innards can be reached without unbolting it. It's clear from the picture I don't have dust collection yet, though I do have the accessory kit's dust bag (still pristine and in the box).
On open stands it's easy to vacuum out the inside occasionally and do whatever else needs to be done in there.
So I guess my question is whether I'll be ok bolting it onto the top as it is, or whether it's better to cut an opening, or forget the solid top and make more framework.
The photo is pretty funky because of the limits of night-time and a glassed in porch, but it's good enough to show the top, which is 3/4" oak plywood.
As always, thanks for everybody's help.
LCHIEN
