Call me stubborn, but I guess I was just more than a little bit irritated at not being able to get new brushes for my pre-'96 BT3000. So, I jury-rigged some off the shelf brushes that are thinner than the originals. I figured, what the heck, the motor is shot, anyway, and the guy at the motor shop took such pity on me that he didn't charge me for the new brushes. Anyway, the motor runs (not under load) with the new brushes, but there's a fair bit of arcing at the commutator. Will it work, or just fry eventually? Will the brushes conform to the shape of the commutator with time and arc less? Should I get second job to take up what some of you probably think is too much spare time and use the money to buy a new saw?
?Too much commutator spark?
I don't have a lot of experience but I think arcing is normal and will improve as the brushes wear in.
BT3 FAQ - https://www.sawdustzone.org/forum/di...sked-questions -
Yep. New brushes do arc pretty good. Stinks too. If they are not a good fit, I don't think they will last very long. I think I would bite the bullet and pick up another motor from a part out. The newer motors have more umph anyway and I think you would be happier in the long run.
http://www.bt3central.com/showthread.php?t=23901Last edited by Stytooner; 09-22-2006, 06:29 AM.LeeComment
LCHIEN
