Trio @ woodcraft
  • durango dude
    • Mar 2011
    • 937
    Trio @ woodcraft
    Goodness, the price has dropped and dropped and dropped.
    The Trio is being carried by Woodcraft for $55.
    Not a lot of accessories available for it, though.
  • radhak
    • 3061
    • Miramar, FL
    • Right Tilt 3HP Unisaw
    Dunno what Trio is, so searched for it, and for whatever reason it only comes up with
    http://www.woodcraft.com/product/200...an-no-673.aspx
    but it's only $9...
    - Aristotle
      • 22012
      my woodcraft search comes up with this:
      http://www.woodcraft.com/Product/208...-Tool-Kit.aspx
      WHy do I want one? WHat is it, a dremel tool with a jig saw like grip and foot?
      • DannyT
        • Sep 2012
        • 28
        • Groveport, OH
        they are also on ebay for 39.99 buy it now. 9.99 shipping
        amazon has them for 59.99 with free shipping
        • durango dude
          • Mar 2011
          • 937
          WHy do I want one?
          That's the question I suspect Dremel hasn't been able to answer ---- ergo the price of the trio has dropped quickly.
          If my memory serves me correct -- the original MSRP of the Trio was around $170.
          • Hoakie
            • Feb 2007
            • 382
            • Iowa
            This may contribute to the issue as well
            "Note: The Dremel Trio uses 3/16 - inch shank accessories. Dremel rotary tool accessories are not compatible with the Trio tool."
            John
              So, what's the deal with the Trio...anybody have one...is it any good?
                That was a stupid move.
                A bit more on their website:http://www.dremel.com/en-us/customer...s/default.aspx
                Changing accessories
                The Collet
                A collet is the most precise way to hold an accessory (bit) in a high speed rotary tool or the Dremel Trio. The collet is located underneath the collet nut, inserted in the end of the tool’s shaft.
                Rotary tool collet
                There are 4 different sized collets available to accommodate different accessory shank sizes from 1/8 inch down to 1/32 inch. It is essential to use the correct sized collet for each accessory. The collets are marked with corresponding shank size: no rings – 1/8 inch (480), 1 ring – 1/32 inch (483), 2 rings – 1/16 inch (482), 3 rings – 3/32 inch (481).
                Dremel Trio™ collet
                The Dremel Trio tool uses a 3/16” collet for all Trio accessories. Trio accessories are exclusive to the Dremel Trio tool system and are not interchangeable with Dremel rotary tools. See your owner's manual for more detailed information on collets.
                  • 22012
                  it sounds like I don't want or need one. A tool that doesn't take standard bits even of its own maker and no one can give a recommendation for.
