Great deal on retractable light
  • tommyt654
    • Nov 2008
    • 2334
    http://www.sears.com/shc/s/p_10153_1...00100312&aff=Y , decent price and has another outlet in handle + retractable cord 1/2 price, good to have hangin around in the shop. Price drops to $12.50 when added to cart
    "It is the lesser man that refuse's to listen to the voice of experience"
  • unknown poster
    • 219
    I have a similar reel. I had the breaker for my garage door opener switched to a GFI and mounted the reel to the ceiling, plugged into the GDO outlet. This is one of my favorite shop tricks, now I have power everywhere (even outside) without having to roll out an extension cord.
    • greenacres2
      • Dec 2011
      • 633
      • La Porte, IN
      Good price for what it is, but it's only an 18-3 cord so keep an eye on what you plug in. Mine is about 20 years old, great to have around for light. Been keeping an eye out for a 12-3 retractable reel (no light, just a cord) but not at $60-$70.
      Earl
      • mclear6
        • 110
        • Northern NJ
        looks like deal is over.
          Earl
          Another thing to remember when using retractable cords, if you are loading the cord to even a fraction of the maximum amp rating, you need to have the cord fully extended. THe reason is that the heat will build up in a coiled cord and exceed the safe temperature rating. Wire gauge ampacity is determined by the amount of copper (leading to heating from resistance) and also from heat buildup (wire must be laid out straight so that heat can escape/ If the wire is tightly coiled it will heat up faster for the same resistance and reduce the allowable AMP rating of the wire. If using anything more than a light load you need to extend the wire all the way out.
          A 12/3 retractable cord of any useful length will be quite large, they have to make the spool diameter larger because the wire is so much larger and stiffer. I've never seen one, I think in part because of the self-heating concern and partly because of the size.
            It was a fair deal for what it was. I prefer just the cord lights, especially if there is a lot of floor space. The incandescent bulbs get hot, unlike the fluorescent type.
            • greenacres2
              • Dec 2011
              • 633
              • La Porte, IN
              Good point on the heat Loring. Here you go...
              http://www.rockler.com/product.cfm?p...campaign=V2114
              It's a 30' cord, 12/3. Looking at the picture mounted to a 2 x 4, I'd have to guess the reel is 15" or so in diameter.
              earl
