Porter-Cable 690LR 11-Amp Fixed-Base Router
  • Kalkan
    Handtools only
    • May 2011
    • 2
    Amazon.com has this router for $121.49 with a $20.00 discount bringing it to just over a hundred bucks.
    Mine will be arriving Tuesday
    • 22108
    its a classic design but there are much improved router designs out there, even from Porter cable. But I guess they all do cost around $200 with a couple of bases compared to $100
    • sweensdv
      • 2873
      • WI
      • Baileigh TS-1040P-50
      What a difference a year makes. Last year Amazon and others had this same router for $99 with an additional $20 rebate. I actually got one at Menards where they had them for $79 plus the $20 rebate at the same time as eveyone else was at $99. For smaller bits in a hand held operation this router ranks right up there with anyone elses.
      • Knottscott
        • 3815
        • Rochester, NY.
        • 2008 Shop Fox W1677
        Best price I've seen in a while.
        • phrog
          • Jul 2005
          • 1796
          • Chattanooga, TN, USA.
          Had a 690 for years and love it. Never found a job it couldn't do. Bought a plunge base for it and found it to be great too.
          Richard
          • mrhans
            • Oct 2011
            • 22
            • Chicago, Illinois 60640
            Ditto that. I have one mounted under a table and another in a D Handle. Havent seen a reason yet to change out from my PC routers. If youre into routing, I hope youre also into hearing protection.
            • Sawatzky
              • 359
              • CA
              I have had one for 7 years and love it! Great router for table use and hand held. I don't know about the newer ones, but mine seems indestructible.
              • phrog
                • Jul 2005
                • 1796
                mrhans, what is hearing protection? Just kidding ! I have a set of the muffs but have been neglecting them lately. Thanks for reminding us.
                Richard
                  I have two 690 motors and 4 bases. One single speed motor and 1 variable speed. I use them when I need to do something my Bosch Colt can't handle or when I need two router tables. Dovetails for drawers is probably my most frequent use. But I've built a bunch of raised panel doors with my 690s. They are not the latest and greatest but they work.
                  I had to replace a switch in my single speed model. I check the brushes periodically but they haven't required replacement yet. Good tool
                  • mrhans
                    • Oct 2011
                    • 22
                    Youre welcome. I have pretty severe tinnitus from rock n roll and then later in life; power tools. It's a drag and I dont want it to worsen. If you could hear (for a little while) what I cannot stop hearing I think you'd never forget your muffs. Hope that doesnt sound too preachy.
                    • Kalkan
                      Handtools only
                      • May 2011
                      • 2
                      Ok, so my router arrived last night. It seems perfect my my occasional hobby use, but as I was checking it out, I noticed something that's confusing me. I'm sure those of you familiar with this router can help me.
                      The hole in the sub-base where you insert your guide bushing has 4 concentric "tangs" that supposedly will center the bushing in the recess. Two of the tangs are spaced at .370 inches and the other two are spaced at .378 inches.
                      The rims on my cheapo guide bushings that fit perfectly in my ancient PC model 1100 router/ 1101 base measure .3765 inches.
                      What's up with the "oblong" spacing in my new router base?
                      Thanks for any insight.
