HF framing nailer-$49.99 on black friday
  • Chris S
    • May 2009
    • 31
    I can't find the link right now, but I saw that the HF 21 degree framing nailer was gonna be $49.99 on Black Friday. This is a steal.
  • glenns5900
    • 70
    • Longmont CO
    • Mao Shan TSC10L
    Double check that it doesn't shoot headless nails. Most building codes do not allow headless framing nails to be used for structures.
    Don't do anything in life that would cause the minister to have to lie at your funeral.
      AFAIK, the HF 21degree framer only shoots plastic-collated full-head nails.
        I think this is the one OP referred to:
        http://www.black-friday.net/harborfreight-ad-scan.html
        • parnelli
          • 585
          Just checked the manual online and that's what it says.
          • tsbrewers
            • 207
            I think you mean clipped head, instead of headless.
            Brew
            • messmaker
              • 1495
              • RICHMOND, KY, USA.
              • Ridgid 2424
              I am not sure I don't prefer clipped head nailers. They hold a lot more nails and will sink the head a bit into most material. Great on decks. I have two decks and the one that was built with a clipped head nailer has way fewer pop-ups.
                • 9523
                FWIW, I got my 28 degree nailer for the same listed sale price, minus the 20% discount... I seem to have better luck finding the 28 degree nails around here...
                If I had it to do over again, I would actually consider the 6 in 1 framing nailer. Will shoot clipped, or full head nails, collated at 21, 28, or 34 deg... Should be super easy to find nails for that just about anywhere...
                • Chris S
                  • May 2009
                  • 31
                  That's the one that I have. I just usually pick up whatever nails HF has on sale. I've shot all sizes and brands through it without a single jam. You have to be careful with the HF nails. Some say "galvanized", but none that I've ever seen are hot dipped. Their "galvinized" still rust.
                    • 9523
                    Electro plated instead of hot dipped... Not specifically a Harbor Freight problem. Just the type of galvanizing. I bet they are fine in Arizona...
