Sears micro-positioning device
  • Kavoom
    • Mar 2010
    • 43
    • Sears 21289
    I saw this on the Sears site. 29.99
    http://www.sears.com/shc/s/p_10153_12605_00922214000P
    "Allows micro-adjustments of Rip Fence in 1/64 in. increments." It comes up with the 21829, but says it's for another unit, however the one reviewer on it says he is using it on a Bt3x00.
    Anybody used one?
    Kavoom
    Upside Down and Backwards
    I use one on my BT3100. It is exactly the same as the one sold by Ryobi except it has the Craftsman name on it. I bought it from Craftsman because it was cheaper and easier to find. It is very useful. If you are trying to get a precise width, for instance, you can position the fence slightly oversize, lock the positioner down, make a cut, and then precisely reposition the fence. I use it for making tenons too. I have a jig that rides the rip fence and holds the piece vertical. I reposition the fence in small increments to get the tenon width just right.
    The one modification I made to the positioner was to epoxy a small rare earth magnet to the hook piece and a small washer to the rip fence. This lets me attach and detach the positioner without lifting the fence. It also eliminates any slop in the attachment.
      it works on the BT3000/BT3100, Sears 22811, 21829 and other sears variants of the BT3x. The one you're looking at is a sears labelled Ryobi supplied unit.
      I have had one for years, works really well. More info on the micropositioner in my FAQ (see sig line)
      • Kavoom
        • Mar 2010
        • 43
        • Sears 21289
        Thanks for the feedback. I got your Faq LChien I'll check that out.
        Kavoom
        • wouldchuck
          • Sep 2005
          • 70
          • Richmond, VA, USA.
          Just ordered it for $25.49, online special.
          • mac_daddy
            • May 2006
            • 84
            • Sugar Land, TX
            If you are into cashbacks, don't forget to login to Bing and then search for Sears in the company and then follow the links to the sears main site. I believe it is at 8% cashback for Sears.
