20% off Harbor Freight monthly
    • 9551
    Originally posted by phi1l
    Hi. I have one of these & I noticed that it works fine for small short duration jobs, but if it stays on for any period of time, the transmission area gets quite hot. So, I think I will reserve it for the smaller close quarters areas it is best at.
    Which one? I am assuming you mean the SCMS, there are two item #s.
    #98194, the Orange motor housing model and the #96698 with the burgundy motor housing.
    I have read some reviews of the 98194 which indicated rapid heat buildup, and accuracy issues, the 96998 only complaint I have seen so far is a pretty lousy blade, which is no stunner there...
    • tjr
      • Oct 2008
      • 167
      • at the falls of the Ohio
      • BT3000 (1 3/4 of them)
      In the recent HF mailer there's a coupon for 12" SCMS for $129.99 that applies to models 98194, 96698, and 91852. I wouldn't be too surprised it there's a $119.99 coupon floating around too. From what I've seen, each store usually only stocks one model of each tool type, so it may be a bit tricky to find a particular model. Maybe they can order the other models that they don't stock?
        • 9551
        Last time I was there, my local HF had a full pallet of each #98194, the Orange motor housing model and the #96698 with the burgundy motor housing.
        They also had full pallets of the 40400 air compressor, and some welders, and a few other non WW related items...
