HF drill press
  • JaiPea
    • 41
    HF drill press
    http://www.harborfreight.com/cpi/cta...emnumber=38119
    HF has this on sale for half-price.
    Is this one of the better tools HF sells or does it fall into the barely adequate category?
    With a 2" spindle stroke, I would pass that one up.
    • docrowan
      • Mar 2007
      • 893
      • New Albany, MS
      I have this unit and have been pleased with it. If you do not have a drill press at all it will be helpful. No problems with operation, just limited on the size. It's been reasonably accurate, quiet, and hasn't balked at anything I've drilled with it.
      - Chris.
        I have had that model for several years. Got it for $40.
        It drills holes. It's too small. The spindle falls off periodically, so I press it back on.
        • Bob Crosley
          • 178
          • Valrico, Florida.
          I'm finding benchtop Deltas, etc. used for $40 all day long on craigslist. I'd feel better with a used Delta than a new HF. I have nothing against HF tools (for the good ones) but I think the Deltas are better made.
          • JoeyGee
            • 1509
            • Sylvania, OH, USA.
            I've had the HF version (also paid $40) and the identical Craftsman, which I inherited from my brother. The HF vibrated a ton and would not drill straight. The CMAN works just fine within it's own limitations. I'm sure it's not a HF thing, just luck of the draw that the particular one I got was bad since they are both identical.
            The one thing I don't like is how the table attaches to the shaft. It "floats" on the post and moves laterally very easily. It doesn't have the crank and geared track like others.
            • gjat
              • 686
              • Valrico (Tampa), Florida.
              I find mine adequate for 95% of what I use it for. Quiet, accurate enough, powerful enough, but it is VERY small. I had a floor model i sold because of limited space. You're not getting more than what you pay for it. If I didn't need one in a short period, I would have held out for a used 'whatever' from Craigslist.
              • tfischer
                • 2349
                Lots of us here have this one:
                http://www.harborfreight.com/cpi/cta...emnumber=43378
                It routinely goes on sale (I think I paid about $140). It's a nice DP, especially for the money. I sometimes find myself wishing I had more spindle stroke even than that one, so I think 2" would be positively limiting...
                • Sawatzky
                  • 359
                  • CA
                  I also have this drill press. Other than not being very powerful, I have not had a need for a drill press with a longer spindle travel. It does everything I need it to, it just takes time to drill big holes. I mostly use it for drilling forstener holes for cabinet doors. It works but could benefit from more power. I also use it with a set of drum sanders and it works great as a spindle sander.
                    I have that same DP, just with a Northern Tool label on it and red paint... It's okay, especially for what I paid for it.
                    I made a HUGE mistake and allowed myself to drool over the Steel City 17" DP at Woodcraft this weekend...
                    I honestly find the over 3" stroke of my current DP limiting. I can't imagine trying to use a DP that only does 2" travel...
                    But then again I guess it all depends on what you are drilling for...
                    I am drilling axle bore holes in toy cars made from 2x4 laminations... Not exactly the easiest thing to do... I have had to stop a hole, raise the table and continue just to be able to drill through... A real PITA, and probably not exactly super safe, but it works...
                    There are times I wish my DP was a benchtop model though, on one of those flip stands shared with the planer to free up floor space... But honestly, I have nothing to complain about with my floor model DP. I added some of the nicer touches like a work tray, DP fence, and retractable chuck key holder.
                    So long winded explaination, if you can do what you need to do with this DP then it might just be a bargain, but if it is too limiting, it is a waste of money.
                      • 22109
                      if you need a light-duty, DP and don't need to drill deep materials or large items then this will do.
                      But for a general purpose shop you might get a bigger one for a bit more money.
                      this one's got the no crank table lift, small vertical quill travel and limited swing plus a smaller motor. You get what you pay for.
                      • Knottscott
                        • 3815
                        • Rochester, NY.
                        • 2008 Shop Fox W1677
                        I've got the benchtop version of this one (38142), and think it's on the impressive side, far exceeding expectations. Not sure I'd pay $80 for the model in the OP, but if on sale for $40, it's should beat nothing.
                        • JaiPea
                          • 41
                          Thanks guys
                          • frumper64
                            • 376
                            • Garland, Tx, USA.
                            I also have had this drill press for a couple of years and have been well served by it. It is indeed limited on size and number of speeds, but it is hard to beat for the price if you can live with the limitations.
                            64sedan_at_gmail.com
