BT Accessory Kit
  • bert11
    • 111
    • Wayne, Ohio, USA.
    • Now a Sears 21829
    BT Accessory Kit
    Was in Findlay, Ohio BORG today and saw several accessory kits on sale for $79 with 50% off on top of that making cost around $40
    If you\"re gonna be dumb
    You gotta be tough
  • tohellwithuga
    • 234
    • GA
    I was actually looking for the kits (before I saw your post about the sale) but have not been able to find them. Where are they usually kept? I walked up and down every tool aisle 20 times probably... Couldn't find an orange apron to ask of course.
    • Stormbringer
      • 1387
      • Floral Park, NY
      • Bosch 4000
      Every now and again I eye-spyed one that seems like it was just put out on the shelf because somebody found it under the trash compactor (that usually the shape their in). However, the Home Depot in Elmont NY had one in good condition this past weekend. Did not notice the price. Sorry.
      Greg
      • Dolsie
        • 21
        they appear to be available at Homedepot.com again (I think they were sold out for a while) Listed at $99.
        • grage
          • 7
          • Wisconsin.
          I just checked a store in northern Wisconsin, there's a couple in stock there, but still marked at the $80 discounted price. Staff doesn't seem to know where to put them as they seem to move around between the pile of Ryobi stuff and the display table saws and the shelved table saws.
          I was hoping these would have been marked down a bit more. $40 is a steal, $80 is a little more than it seems worth for my use.
            • 22057
            You have to wonder what numb-nuts buyer arranged this after the BT3100 were discontinued.
            • bert11
              • 111
              • Wayne, Ohio, USA.
              • Now a Sears 21829
              you never know
              you never know where these might be--this time they were in middle aisle under a table--last time they werre in overhead in flooring---next time ?????
              You gotta be tough
                I saw three of them sitting among the table saws at the local store last weekend. They were sitting right where the BT3100 used to sit, lo these many months ago. Sittng there in there squalid little stack, no price, no sticker.
                sniff.
                • kw
                  • 29
                  • Vero Beach, FL, USA.
                  BTAccessory Kit
                  I saw 3 accessory kits @ the Vero Beach, FL HD. If my memory serves me right they were marked down to $79 each.
                  • Pakaderm
                    • 116
                    Does that mounting plate work for most routers or just Ryobi? Is it required for me to mount a bosch or hitachi router under the bt3100 table?
                    Thanks,
                    -Pak
                    • vanslyke
                      • Jul 2006
                      • 10
                      Not sure about bosch or hitachi. I did not fit my dewalt so I drilled new holes. It
                      • Jeffrey Schronce
                        • 3822
                        • York, PA, USA.
                        • 22124
                        I don't think I have ever seen that phrase in writing. Nice hand!
                        • wdreamsmaycome
                          • 60
                          • Vancouver, Canada
                          • bt3100 (of course!)
                          has anybody ever seen these in Canada? I called a few home depot stores and nobody knew anything about them, they all said that I'd have to order them direct from ryobi (???)
                            • 22057
                            Thanks,
                            -Pak
                            They have holes for the pattern used by Ryobi and the Ryobi-built Craftsman routers.
                            But its easy to mount your own router on the aluminum plate.
                            Take the plastic scuffplate off the router you have and center it over the hole in the plate as best you can by eyeball. Use a pencil and mark the pattern of the hole susing the baseplate as a template.
                            It's best if you mark the center of these holes with a centerpunch, making a dimple in the aluminum. Use a small bit and start the hole using the dimple, then switch to the larger bit (that clears the screw) and drill through. Aluminum is very soft and drills quite easily. You should have a sharp bit and the aluminum will come off in curly slivers. If it chips off you have a dull bit. Countersink with a 82 degree countersink bit and make sure you do this from what will be the topside of the plate when mounted.
                            • ggg71
                              • 12
                              • Swampscott, MA
                              For what it's worth I found one at the BORG in Salem, MA. $79. Beat up box. I'd never seen one before...
                              The dustbag, miterslot table, and router mounting kit made it a worthwhile purchase for me.
                              Garth
