2 Irwin circ. saw blades $4.20
  • davidtu
    • 708
    • Seattle, WA
    Good buy? Can I use them?
    Seems like one couldn't go wrong with this deal--BUT my Ryobi 18v Circular Saw takes 5 1/2" blades... these are 5 3/8"... would they work (being 1/8" smaller) or not?
    IRWIN 140152PK 5 3/8" 2 Piece Marathon Thin Kerf Carbide 18 Tooth Framing/Ripping & 80 Tooth Plywood Circular Saw BladesWas: $18.80 $7.49
    Now: $4.20
    LINK:
    http://www.amazon.com/gp/product/B00...lance&n=228013
  • mpphoto
    • May 2006
    • 13
    Irwin blades
    I have the same Ryobi saw; 5 3/8 blades are fine as long as they have a 10mm arbor hole. I looked at the blades you posted but I can't tell. It's a good price, HD sells a two-pack of blades like this for the Ryobi for somewhere between $13 and $20.
    DeWalt also makes 5 3/8 blades that fit this saw (and they also sell for around $20 for two).
    Michael
    • brooks
      • May 2006
      • 106
      I looked up the blades at Irwin and they do seem to have a 10mm hole.
      http://tinyurl.com/ovl46 <-- you can see their table for small blades meant for cordless saws.
      My question is more basic: are these really good blades? Or more of a rough framing type blade? I know one says it's for plywood and has a high tooth count.
      • davidtu
        • 708
        • Seattle, WA
        I went ahead and ordered 'em so I suppose I'll find out how good they are or aren't. Of course, I am doing mainly (look away!) carpentry work right now so I presume they'll be fine for me.
        Thanks for the info on the 10mm hole... never occured to me that there was variance in that aspect! Whew!
        • Aiko
          • 7
          I bought these, have not recieved them yet, but for $2.10 they are probably a good value, irwin is usually middle of the road quality, good for alot of the stuff I do. I don't usually use my cordless saw for fine woodworking anyway.
            • 22056
            smaller blades work in circular saws and table saws, you just can't cut as deep at the maximum (by half the difference or in this case, 1/2 of 1/8", or 1/16th).
            Note the "Plywood" blade has no carbide teeth, just 80 steel teeth as plywood blades usually do.
