quote:Originally posted by wassaw998
If you overpower the "trash can" cyclone, what you end up with is an empty trash can. He's saying, that using the 2 oversized bags w/lower plastic bag is providing so much air flow, that the trash can ends up being worthless as the stuff in it is getting sucked to the bag.
Let me ad this, on a typical cyclone , you do not want anything getting past the cyclone. The idea is all the "stuff" swirls around in the cyclone and falls down into the collection unit and only air passes to the next stage , which typically would be a cart filter. An effecient cyclone would have everything hitting the collector under the cyclone, and nothing hitting the collector under the cart filter and thus the cart filter would have a very very long shelf live and cloging and what not would be of no real concern. The trash can jobs are really not gona catch the small dust, but, they can stop the bigger stuff from passing thru and also help save the impellor from collisions (and I'd suspect, were you to have a cart filter and not a bag, the trash can job would perhaps help save your cart from collisions which could tear it). However, as he pointed out, when you get your system running with a lot of CFM, the trash can jobs typically just flat out fail (they become a full pass thru unit). I suspect were one handy with sheet metal they could form a more proper cyclone in place of the trash can and put that up front and maybe bring back the purpose.
LCHIEN
