Dug into my caster storage closet for 8 identical casters and found these “remains” from 2 polyurethane coaster tires. I’ve seen them crack and fall off the wheel .but never dreamed they would self destruct into such small pieces. This is in a dark closet in my climate controlled shop with temps averaging in the 70fs. One good thing I’ve learned is after a PU caster self destructs the plastic wheel still works satisfactory for shop use if you peel the tire off all of the casters.
Poly caster wheels
Poly caster wheels
I’ve chimed up in numerous times in discussions about polyurethane wheeled casters, always pointing out their tendency to crack and the tire fall off the wheel. Today i
Dug into my caster storage closet for 8 identical casters and found these “remains” from 2 polyurethane coaster tires. I’ve seen them crack and fall off the wheel .but never dreamed they would self destruct into such small pieces. This is in a dark closet in my climate controlled shop with temps averaging in the 70fs. One good thing I’ve learned is after a PU caster self destructs the plastic wheel still works satisfactory for shop use if you peel the tire off all of the casters.Last edited by capncarl; 06-18-2022, 08:05 PM.Tags: None -
Ugh!!!!!!!!
LCHIEN
