Tools explained
    Tools explained
    TOOLS EXPLAINED
    DRILL PRESS : A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
    WIRE WHEEL : Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh sh*t'
    DROP SAW : A portable cutting tool used to make studs too short.
    PLIERS : Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
    BELT SANDER : An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
    HACKSAW : One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
    VISE-GRIPS : Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
    OXYACETYLENE TORCH : Used almost entirely for lighting on fire various flammable objects in your shop. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race..
    TABLE SAW : A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
    HYDRAULIC FLOOR JACK : Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
    BAND SAW : A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
    TWO-TON ENGINE HOIST : A tool for testing the maximum tensile strength of everything you forgot to disconnect.
    PHILLIPS SCREWDRIVER : Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
    STRAIGHT SCREWDRIVER : A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
    PRY BAR : A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
    HOSE CUTTER : A tool used to make hoses too short.
    HAMMER : Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
    UTILITY KNIFE : Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
    ADJUSTABLE WRENCH: aka "Another hammer", aka "the Swedish Nut Lathe", aka "Crescent Wrench". Commonly used as a one size fits all wrench, usually results in rounding off nut heads before the use of pliers. Will randomly adjust size between bolts, resulting in busted buckles, curse words, and multiple threats to any inanimate objects within the immediate vicinity.
    Son of a ***** TOOL : Any handy tool that you grab and throw across the garage while yelling 'Son of a b*tch' at the top of your lungs. It is also, most often, the next tool that you will need.
  • nicer20
    • Sep 2007
    • 365
    • Dublin, CA
    :d:d:d:d
    • Jim Frye
      • 1364
      • Maumee, OH, USA.
      • Ryobi BT3000 & BT3100
      TAPE MEASURE: A measuring device designed with an end hook that will lose its grip as soon as you attempt to mark a dimension on the work piece and allow the tape to move before you can make the mark. The design is so insidious that the problem worsens the longer you fight with it and the longer the measurement is.
      Jim Frye
      The Nut in the Cellar.
        In my first career, I was working at a particularly, let's say less than ideal shoop, on an Audi 5000 that hadn't had the recall yet. Yes it ran away trying to go into the shop. Smashing the brakes and turning off the ignition got the tires to stop smoking. As I stepped to my toolbox I happened to lay my hand my my beautiful Snap On 10mm combination wrench when the shop manager came out to deride me on the issue of the Runaway Audi.
        During the uh, lively debate that ensued, I managed to hurl said wrench out of the shop door, across the parking lot, and somehow through the bushes and to the hungry waiting sewer drain on the far side of the parking lot past the bushes.
        The manager knew he was pushing too far as he turned and went back to his office. It was that very day I decided I was going to put in my notice for that particular national Tire and Auto chain shop, and change careers.
        There were other dirtbag managers I worked for in the field, but this guy made me despise the field entirely for a long time. I've never wanted to hurt someone over professional differences, except that guy. I honestly wanted to HURT him. I knew I had to get out, and that was just the straw that broke the camels back.
